Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
installing injectors
Old Jul 5, 2007 | 02:00 PM
lt1chevelle's Avatar
iam putting new ractronix injectors in my car and i was woundering do the stock clips work> i cant seem to get them to stay on. do i need different ones for the racetronix injectors?
Old Jul 5, 2007 | 02:26 PM
G. McDonald's Avatar
Injectors
I just put 42 lb Ford SVO injectors in my fuel rail and they did not have the same groove as the stock injectors (not sure if this is the same problem you are seeing).
I just took a hacksaw blade and made my own new grooves in the plastic outer body of the injector to accept the stock clip. I have not run it yet but I am fairly sure it will work fine. You may want to do a search on this to confirm but I think some guys go without the clips and just hold the injectors in place in the manifold with the four bolts that hold the fuel rail to the manifold.
Good luck.
Old Jul 5, 2007 | 02:34 PM
Sweetred95ta's Avatar
I'm using a set of 30 lb SVO's without clips. I've been running them like that for years without any problems.
Old Jul 5, 2007 | 03:20 PM
wrd1972's Avatar
The cluips are used to make installation easier, once the injectors are in they serve no purpose.
I have the 30# SVT injectors and the clips worked fine.
Old Jul 5, 2007 | 03:53 PM
ya iam having problems with the clips sliding into the grooves i was thinking about doing the same thing with a hacksaw iam going to insall them tonight ill let you know how it gose
Old Jul 5, 2007 | 03:57 PM
SS MPSTR's Avatar
I used a hacksaw blade on my SVO's too. Worked fine.
Old Jul 5, 2007 | 04:44 PM
Kevin Blown 95 TA's Avatar
If I remember correctly, there's one groove they work in on those, and they might be a little higher or lower than stock, but it works.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
Wilson
Jul 21, 2002 05:08 PM
