Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Help with Accel AFPR
Old Jun 21, 2007 | 08:49 AM
dbusch22's Avatar
i searched here, i called Accel , which is now owned by Mr Gasket and SAT on hold. I went to their website, i couldn't find anything. I submitted a tech question through e mail. they sent me an e mail back asking to call with a reference ticket, which i did, sit on hold sit on hold. I tried calling at different times of the day. It's ridiculous, their customer support is horrible! I FINALLY got a guy to take my call, and he told me that i needed to call a different # for DFI. i said... this isn't part of a DFI system! well for some stupid reason their DFI department handles it. He was quick to pawn me off on someone else and give me their # instead of try to help. So i called that #, they're on training until the 25th.
OBVIOUSLY NO ONE IN THEIR ENTIRE COMPANY KNOWS HOW TO INSTALL THIS PART
Can anyone help? it's a clamshell style AFPR from accel for Lt1, and it LOOKS like i have to dismantle my original FPR and bolt this one up to it somehow. I just don't want to ruin mine to find out i was wrong.
Has anyone here installed one of these before? i'm ready to chuck it and and get a complete one from aeromotive.
Old Jun 21, 2007 | 12:09 PM
Kevin Blown 95 TA's Avatar
Yes, you use parts of your old regulator. If I remember correctly, You have to grind around the outside of the crimp and it comes apart, then you use the new parts to put it back together.
Old Jun 25, 2007 | 06:59 PM
87BlackZ's Avatar
I had one from Crane Cam--it sucked and the BBK didn't look any better.
I got the adjustable aluminum one from Holley. Not only does it look good it is easy to adjust the way it is built. I don't know if it will work on your LT1 as I did have to grind down the upper intake on my TPI to make it fit, but it is over 4yrs installed with no problems
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
Fastbird93
Sep 29, 2015 04:05 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
Slayer
Aug 17, 2015 03:55 PM
