A good aftermarket Opti?
Subscribe
Mar 20, 2018 | 01:23 PM
There has been a lot out about how bad aftermarket optis have been. And GM optis seem to be the way to go. However, I was at the saccitycorvette.com site that sells the AIP opti which has the Mitsubisi module and claims output to 8000 rpm and is used in some racing event. Has anyone had experience with this unit?
Reply
Mar 20, 2018 | 03:08 PM
Re: A good aftermarket Opti?
The rebuilt AC Delco is what most recommend. I have a Dynaspark from before the company changed hands and quality dropped, with no issues.
It seems for something outside AC Delco, some have looked at Ventilated Optispark Distributor | Petris Enterprises
I have not heard of Saccity. Be careful about the module, as they state they use their own Mitsubishi spec module, not a Mitsubishi module specifically. They do provide a 2 year warranty, so as long as you are okay with the possibility of extra work, there is a significant cost difference and a 2 year warranty.
Personally, if it's too good to be true, it probably is.
Reply
Mar 20, 2018 | 09:40 PM
Sac City Corvette resells the AIP (All Ignition Products) Opti for $60 more than AIP sells it for. Haven't heard anything about AIP for at least 5 years. Before that, their Opti was recognized as a certified, complete POS.
Reply
Apr 6, 2018 | 03:02 PM
Thanks for the reply, Fred. Now, how does jet.com advertise a "AC Delco, D8301 by AC Delco" for $151.78 ? Bill
Reply
Apr 6, 2018 | 03:33 PM
I wouldn't trust the site. Again, too good to be true, it probably is.
Reply
Apr 6, 2018 | 03:43 PM
I just looked at Rockauto and they now have a GM Delphi Pn :1938351 for $224 with core
and a Pn: 19212399 for $307. incl harness with core. Some place I read where not all harness adapters were the same.
Reply
Apr 6, 2018 | 09:03 PM
I must be late. I just checked Rock Auto and was informed the Delphi Opti is not available.
Reply
Apr 5, 2019 | 02:59 PM
I am not sure I need an opti. It is not oil covered. Maybe I need to check the computer.
Reply
Apr 5, 2019 | 10:29 PM
What specific problems are you experiencing?
Reply
Apr 6, 2019 | 11:06 AM
Well, if I remember it just seemed to have a misfire.
Reply
Apr 6, 2019 | 11:14 AM
The car has recent plugs and plug wires.
Reply
Apr 6, 2019 | 11:35 AM
Quote: Well, if I remember it just seemed to have a misfire.
Not a lot to go on....
Misfiring under what conditions? Have you checked the fuel pressure? Have you scanned for codes? Have you had the coil and ICM tested? Did you inspect the Opti plug wire terminals for corrosion when you changed the wires?
Reply
Apr 9, 2019 | 09:30 PM
Quote: Thanks for the reply, Fred. Now, how does jet.com advertise a "AC Delco, D8301 by AC Delco" for $151.78 ? Bill
Because it is a cap and rotor kit-not a complete optispark.
Reply
Apr 9, 2019 | 10:13 PM
Kind of odd.... there's a one year gap between the posts...... 4/6/2018 ——> 4/5/2019.
Reply
Subscribe
