Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel System
Old Jul 14, 2008 | 06:43 PM
Ohz28buicksky72IOsta's Avatar
Fuel System
How efficient is the stock fuel system on a 1994 z28? I have the cc306 and sometimes it feels like its falling on its face.
Old Jul 14, 2008 | 11:53 PM
LJM97Z's Avatar
Your best friend will be a fuel pressure tester, it'll tell you whats going on, first change the fuel filter if you haven't allready, the stock fuel system should be fine & adaquit enough, so spend the 45.00 bucks & get the tester, just make sure you check it with the regulator vacuum hose off ( if a 94 is equipt with one), i'm sure it is.
Old Jul 22, 2008 | 08:49 AM
mzgp5x's Avatar
I did not like the small dia stock plumbing, and, the very nonefficient tube bends for Hi-Perf Mod applications. Replaced it with (2) -6an (3/8) Aeroquip socketless hoses (2 walbro 255lph intank pumps), and, all -6an and -8an fittings. The problem was not pressure but volume delivery. Probably OK for NA mild applications. (App... 383 D1 M6 Camaro)
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
Jul 4, 2005 05:00 PM
