Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel Cell with In Line Pump Questions
Old Apr 27, 2007 | 01:28 PM
HectorM52's Avatar
Okay, I've got a fuel cell with an in-line pump...
I have a Holley 12-920 OR some would say it is a Walbro GSL-392 sold in a Holley box... I don't know the difference.
I've got a 20-gallon RCI fuel cell.
Now, the directions tell me to put a fuel filter BEFORE the pump and AFTER the pump. It gave me a part number Holley 562-1 that I have purchased for the AFTER pump. Now I need the BEFORE pump. Here is what the directions have said about the BEFORE pump:
"A low-pressure fuel filter MUST be used on the inlet of these fuel pumps. Failure to do this WILL damage the pump, which will VOID the warranty.
Use a filter that has a filtration rating of 40-100 microns. Use filters that can flow at least 600 pounds per hour (100 gallons per hour) with minimal pressure drop.
For moderate power applications, you can use a typical 3/8" barb universal carbureted fuel filter, commonly found at auto parts stores."
Now here's my question: Do you know of a good in-line 3/8" filter that would work in this situation? Keep in mind I can't spend $150 on a ridiculous Aeromotive filters (not right now, at least) and I'd rather not have to buy AN- adapters. So let's try to keep it with typical rubber-hose setups...
Secondly, I've got these two "vents" on top of my cell. Anyone know how to close them off? I've heard that I need a "vacuum breaker" or something up there to keep it open until it flips over (hope that doesn't ever happen...) It looks like they accept AN- fittings, probably AN-10 fittings.
Thanks guys!!!
Old Apr 27, 2007 | 01:31 PM
HectorM52's Avatar
PS - I'm running around 350-hp to the wheels so I can't go with a cheap Russell filter before the pump. I've actually already bought one and then realized that I can't use it.
Old Apr 28, 2007 | 08:49 PM
HectorM52's Avatar
Old Apr 28, 2007 | 08:59 PM
mdacton's Avatar
the lo press filter you want is going to look like a mount with a can on the bottom....
You need to buy a cap for one side at the top of the cell and a rollover vent for the other side
Old May 2, 2007 | 05:23 AM
Guest47904's Avatar
Guest
Went through the wrong filter so I know!
I already went through a pump cause Summit sent the wrong filter so I already burnt up a pump and had it rebuilt.
The inlet filter should not be finer than 100 microns. Try to keep the size near that of the pump.
For the breather look here:
http://store.summitracing.com/egnsea...115+4294849067
When ever you are looking for something you can't find, use Summit "by department".
Old May 2, 2007 | 08:04 AM
HectorM52's Avatar
Thanks guys!
I am searching right now for a before-pump filter.
Old May 29, 2007 | 01:28 PM
HectorM52's Avatar
I guess I'll update my own thread...
I finally broke down and called the manufacturer, Holley. They knew exactly what I needed. They suggested a part for an '84 Buick Grand National. They gave me a part number 562-3 which is a small plastic white fuel filter. It says it is for high-pressure FI applications. Works like a charm so far.
HectorM52
Jul 30, 2017 11:46 AM
pologreen97z
Dec 2, 2014 10:42 AM
Jul 4, 2005 05:00 PM
BLOWNBIRD
May 28, 2003 01:02 AM
