Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Cyliders not there on start up
Old Nov 8, 2007 | 05:59 PM
Wart Hog's Avatar
Hey Guys, I need a litle help.
I have a problem that has just started on my 95 Z, LT1.
On cold starts, it seems as if half of the cylinders aren't hitting. I rev it a little and it doesn't clear out. I shut it off and restart and all is well.
It started about 2 weeks after changing plugs, wires and water pump, but the temp. dropped here in that time as well.
Could this be an Opti problem, fuel supply? I hear the prime when I turn the switch on.
Maybe MAF or charcoal canister?
It doesn;t give any SES fault codes when it does this either, making it even more of an enigma.
TIA, Charles
Old Nov 8, 2007 | 10:51 PM
TobyZ28's Avatar
Sounds electrical for sure, check your ground and your battery terminals to make sure theyre all making good contact.
Old Nov 8, 2007 | 11:55 PM
mdenz3's Avatar
When you changed the water pump did the Opti get wet?
Old Nov 9, 2007 | 07:37 PM
Wart Hog's Avatar
actully the water pump was leaking on the opti. I smelled coolant and found it. I kinda thought it was the opti. I think the 95 opti is vented. I checked the battery and it's all good. I thought it might have a bad ground.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
