Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
CS144 Lt1 Alternators question
Old Jun 30, 2010 | 11:24 PM
brahm's Avatar
Can they all be run as a one wire, or do they need to be converted? The alternator that came with my motor works as a one wire but it fried, I've got a rebuild kit on the way, but I was going to grab a spare used stock lt1 alternator just in case I can't get it rebuilt in time for a race next week. I don't believe I still have the rest of the alternator wires in my harness from the retrofit so I want to make sure the stock one will still work for me, or if it's a quick fix.
-Brahm
Old Jun 30, 2010 | 11:32 PM
The CS 144 needs an exciter wire.
Old Jun 30, 2010 | 11:41 PM
brahm's Avatar
Thanks for the prompt response, I purchased this kit to rebuild my current one, but am now wondering if that will turn it back from a one wire into a stock style alternator.
http://cgi.ebay.com/ebaymotors/DELCO...item5ad69b1321
Do you know by chance what internal part converts it from a multiwire to a 1 wire setup?
Old Jul 1, 2010 | 08:15 AM
From doing some Googling, it looks like the voltage regulator is different. However, I have read that you lose voltage sensing with a 1 wire and it would be better to keep that for a street car.
Old Jul 1, 2010 | 11:34 AM
brahm's Avatar
Thanks again for the reply. I talked to the guy who I ordered the kit from and he said the same. He switched the voltage regulator for a 1 wire one. I've never had an issue running a 1wire on the street typically you just need to excite it with a quick rev. I'm hoping to relocate my alternator since I'm not using power steering or ac, so in the long run it will be much cleaner, and easier with a 1 wire setup.
Gtpguy
Jan 26, 2015 04:50 PM
Hurin
Dec 13, 2014 07:38 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
JSK333
Sep 9, 2002 10:33 PM
