Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Coil resitance
Old Apr 18, 2010 | 05:55 PM
Rashiki's Avatar
Coil resitance
Going through the car to try and pin down a misfire, and checked the resistance of the stock, 150k mile 96 Z28's coil. Turns out it's about 2800 to 3500 ohms.... Am I doing something wrong or is the coil giving up the ghost? And reason the resistance would go down? Could it cause a misfire under acceleration? Thank you in advance for your help!
Old Apr 21, 2010 | 11:31 AM
Rashiki's Avatar
anyone?
Old Apr 21, 2010 | 10:01 PM
TGK's Avatar
TGK
From: Knoxville, Tennessee/Mooresville, N.C./Phoenix, AZ/Bristol, TN
You should do it like this -
http://shbox.com/1/coil_testing.jpg
I don't know what you mean by giving up the ghost, and what makes you think resistance has gone down? Have you checked it before?
Since most aftermarket coils run at a lower resistance, then I would say your's is okay. I would think there is no cause for a misfire. If you want too, find someone with a car that isn't missing that you can swap coils with to see if the problem goes away or not.
I would try this next if I was you though.
http://shbox.com/1/4th_gen_tech2.html#opti_test
I just got done replacing my opti, and it fixed my 1500-2000rpm hesistation.
Old Apr 21, 2010 | 10:33 PM
MikeGyver's Avatar
Here's how I tested mine lol
http://www.youtube.com/watch?v=_gwResvzf0E
Old Apr 22, 2010 | 11:55 AM
Rashiki's Avatar
Yea, i ran through both of shoebox's tests, and my coil is nowhere near 8k megaohm, it was more like 3k megaohm. It's a stock coil, so i didn't know what the deal was, usually resistance goes up with time. The rest of the tests pass, so it's either coil, icm, or wires. When i tested the coil, there was some corrosion in the housing where the coil wire goes, so i'll replace it anyway i guess. One more thing to eliminate!
I like that test Mike, makes me want to go watch star wars now :P
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
