Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Which coil delco or aftermarket
Old Aug 10, 2007 | 08:18 PM
jeffwof1z28's Avatar
Wondering what others recommend for coils for the 96 lt1. Mine is starting to fade, should I replace with a delco? or aftermarket? Any opinions would be appreciated.
Old Aug 10, 2007 | 10:22 PM
The stock 96 coils are pretty good. What evidence do you have yours is "fading"?
Old Aug 11, 2007 | 02:45 PM
Hi thanks, At low rpm's, say goin from 35 mph in 5 th gear accelerating staying in 5th to freeway speed it has some hesitation till the rpm's build a little higher. I've changed the plugs optispark dist and rotor, replaced with new delco plat wires. So I pretty much narrowed it down to the coil. Am I right??
Old Aug 11, 2007 | 03:12 PM
Possibly. It is not easy to judge the output of the coil, unless it is suitably weak. The upside is that it is not expensive to replace.
Old Sep 18, 2007 | 04:02 PM
stopthatman's Avatar
and the wires make a big difference
95_Z28/SS
May 20, 2015 01:23 PM
grgguy
17
Feb 23, 2015 07:57 PM
Catmaigne
Dec 25, 2014 12:16 PM
