Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Carb LT1 Guys in here please!!
Old May 28, 2008 | 01:35 PM
  #16
hot_red_z28's Avatar
Originally Posted by Injuneer
I just saw a "Q&A" in the current issue of Hot Rod magazine with regard to running an EFI high pressure pump with a carb. Look at page 135 of the June 2008 issue. They show a high pressure pump feeding a "tee", with a Kinsler bypass valve set at 8psi allowing fuel to return back to the tank from one branch of the tee, and the other branch of the tee feeding a Holley PN 12-803 regulator (non-bypass) set at 6.5-7psi, with dual feeds out of the regulator to the carb.
I've been shopping around for the same parts lately... I found this one... It's the 12-803, but it's a bypass version that essentially has the "T" bypass fitting built in...
http://www.holley.com/12-803BP.asp
Old May 28, 2008 | 09:47 PM
  #17
BMoney's Avatar
I switched my car over to a gen I small block, and used the stock pump in the tank, a bypass holley regulator, I used all the factory fuel lines, it was pretty easy, I would recommend a bypass to return the fuel to the tank, with out it, the fuel pump will be working too hard and hitting a dead end at the regulator. you might have to actually restrict the bypass a little. I used a hose clamp and just watched my guage as i tightend the clamp.
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Red97LT1
Aug 7, 2002 05:45 PM
