Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
car will not start
Old Jun 17, 2008 | 01:49 AM
chunick's Avatar
car will not start
I have a 1995 Camaro, 3.4 L ...
It seems that when I put my keys in the ignition and turn to on or try to start I get nothing, nothing happens and nothing turns over. The gauges do not have any power, including my power windows. Everything else seems to work and have power, the battery has juice (power doors work, interior/exterior lights). I have checked all the fuses and no blown fuses.
I believe the ignition fuse is getting no power (will double check tomorrow though).
Any thoughts or a direction I should go next ? (I have the haynes 1993 thru 1996 camaro repair manual)
thanks in advance.
Old Jun 17, 2008 | 02:02 AM
lt1stroker's Avatar
^ i had the same problem. check your coil. also does it crank at all?
Old Jun 17, 2008 | 02:18 AM
chunick's Avatar
Thanks, I will look into the coil tomorrow. Me and a friend will be looking at my car most of the day.
No it does not crank or make any noises. When I put the key in and turn it in either direction, absolutely nothing happens. You would think the battery is dead or something, but I have power elsewhere with no problems.
The only response I get with the key inserted is if the door is open it beeps. Take the key out and beeping stops. So some things still work. All gauges on the dash are dead with no signs of power.
Old Jun 18, 2008 | 10:00 AM
95Z28ConvtM6's Avatar
It's probably your ignition switch. It's located on the top of steering column under the dash. The dash lights are the give away. Everything goes dead, no dash lights or gauges, no clicks...
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
blac94Z
Dec 2, 2014 12:09 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
