Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Boost control knob
Old Feb 8, 2007 | 03:30 PM
mrmint69's Avatar
Boost control ****
I have the msd 6btm and it has the boost control ****. It has 0,1,2 & 3 for settings. What one should i set it on for 6psi's of boost?
Old Feb 9, 2007 | 09:31 AM
Rice Killer87's Avatar
You talking about an adjustable timing retard ****? If so,those are degree's of timing to take out,make a pass in the car and if it breaks up/detonates,just adjust it one level at a time until you find the sweet spot.
Old Feb 10, 2007 | 01:50 PM
Kevin Blown 95 TA's Avatar
I think yours has a max of 15 degrees and the 1 setting is 1 degree/lb boost the 2 is 2 degrees/lb boost, etc. So if you set it to 1 1/2 you will get 1 1/2 degrees/lb of boost - that is about where you should leave it on premium gas. Of course, they aren't quite as accurate as all that, and a dyno tune would help nail it down so you don't waste power.
Henson071
Sep 18, 2015 04:01 PM
96SilverRam
Sep 7, 2015 10:51 PM
Aug 7, 2015 01:26 PM
Henson071
Aug 4, 2015 09:32 AM
