x02 60mm wastegate problem..
Old May 13, 2010 | 04:13 PM
cvccbum's Avatar
Bought a kit off Jon (RealQuick) alongggggg time ago, and now finally have the car driving. It seems I am way over boosting though.
I was told I had the gate setup wrong. I have the compressor side of the turbo running to the top nipple of the WG.
I was told to run the line to the side of the wastegate.. but I don't see any nipple there??
Any help would be appreciated before I blow this thing up!
EDIT: After taking the WG apart and investigating, its obvious I need a nipple on the lower portion of the gate. Does anyone know where I can find one? Theres just a screw there atm.
Old May 13, 2010 | 10:02 PM
MikeGyver's Avatar
You need to apply boost to the side of the diaphragm opposite the spring. Boost pressure is what fights the spring and allows regulation.
Old May 14, 2010 | 12:45 AM
RealQuick's Avatar
Can you remove the one from the top and put it on the side? The top is open to atmosphere anyway.
Old May 14, 2010 | 01:28 AM
Geoff Chadwick's Avatar
I'd take the screw blocking the port down to Home Depot or Lowes (if the two ports arent the same thread) - they should have a thread guide in the hardware and/or plumbing section that'll tell you what thread it is, and then if you can't find one there (or at your local auto parts store) just order an 1/8" barb with the appropriate thread from summit. Easy as pie.
I'd recommend a nipple on the second port (and orient it pointing down) but giving it filtered air isn't 100% critical. Just don't plumb it to the intake manifold or any of the intercooler piping.
Old May 14, 2010 | 12:11 PM
cvccbum's Avatar
The side port of the wastegate is a diff size then the top and its at a very weird angle.. think it needs a special nipple. anyone know if x02 is a replica of another gate?
Old May 14, 2010 | 12:18 PM
I don't know if its a replica - but give em a call, they should be able to tell you what the thread is.
http://www.xo2racing.net/cart/information.php?info_id=4
Old May 14, 2010 | 12:21 PM
cvccbum's Avatar
Thanks man. After looking at it, looks like I can maybe get a small nipple in if I take the rest of the gate apart. I'll give them a call to make things easier
Looks like I can make it work. Just had to take the whole gate apart! I'll be posting dyno #s soon ;D
HibachiZ28
Nov 6, 2015 12:53 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
96SilverRam
Aug 9, 2015 04:15 PM
Wild1
Jan 19, 2004 08:17 PM
SMOKNZ
Jan 3, 2004 09:03 PM
