Will this set-up handle 12 pounds of boost yes or no???
Old Nov 4, 2004 | 08:58 PM
detroit1994z28's Avatar
Will this set-up handle 12 pounds of boost. A guy had this set-up running 10 pounds and made 450rwhp. Will this set-up handle 12pounds and how much horsepower will this make over 10 pounds
355 diamond pistons 9:01 comp. ratio, eagle H beam 6 in connecting rods.
Polished balanced stock crank, 2 bolt mains studded. High volumn oil pump, stock oil pan with drain hole for S/C. Heads ported and polished 2in intake, 1.6 exhaust. comp vaulve springs. comp double roller 1.6 rocker arms. Diamond harden puch rods and guide plates. Comp R lifters and comp 224/236 blower cam
Old Nov 5, 2004 | 10:54 AM
Re: Will this set-up handle 12 pounds of boost yes or no???
ttt
Old Nov 5, 2004 | 11:20 AM
SMOKNZ's Avatar
I ran 18 psi on a stock bottom end minus some Speed-Pro -22cc Forged pistons, oh I did use ARP bolts on the rods too.
Answer to your question, Yes it will last, just make sure it's tuned properly.
Old Nov 5, 2004 | 07:38 PM
NtenseZ28's Avatar
Spend the extra dough on a new forged crank...if it's already apart, you might as well do it. A motor is only as strong as it's weakest component.
If it's already together, my stock rotating assembly handled a 150-shot of N20 on a motor that had only bolt-ons (and 88,000 miles) (P.S. The guy I bought it off of changed the oil every 5000 miles). I've heard if ur shooting for over 450hp, save urself the trouble and change it now. That could be wrong though...haven't chunked an LT1 yet *Knock on wood*
The Eagle H-Beams are rated for like 800 hp or something like that...they're in my 383. The guy who did the machining of my motor said they're one of the best "bang for the buck"
Old Nov 7, 2004 | 09:17 PM
wingnut's Avatar
Has anyone ever wondered how far you could push the 2-bolt block? I mean, just really push it. What were the numbers before the BLOCK gave away and not the rods, crank or pistons. I have heard that some people have used studs (2-bolt) with forged crank, pistons and rods and pushed the 800 HP mark. You think this is true? You know any one who has?
Just a thought.
Preacher Bryan
Old Nov 8, 2004 | 01:19 PM
crash4cyl's Avatar
we're starting with a 2 bolt block...getting 4 bolt splayed mains and shooting for 1300+ Hp. at the crank...of course that will be aided by a PT-96 in the neighbor hood of 15+ PSI of boost......
Chris
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
NewsBot
Sep 14, 2015 09:20 AM
NewsBot
Sep 14, 2015 08:50 AM
tommalcolm
Sep 11, 2015 03:39 PM
