Whos built a DIY A2W intercooler?
Old Aug 5, 2008 | 02:18 PM
Tricked-Out-Toy's Avatar
Looking for some pictures of some DIY intercoolers.
Old Aug 7, 2008 | 10:34 AM
Geoff Chadwick's Avatar
(Only pic I have at the moment)
Inlet and outlet are 3.5" dia that has been slightly oval-ized. Core is like 3.5" or 4" thick, 3.5" tall, about 20" long.
Outlet lines (in the front) go to in front of each wheel where a 10"x10"x3/4" heat exchanger with push fan is mounted. The two lines then merge and go back to the 5 gallon reserve cell in the trunk.
Inlet is in the back of the intercooler, pointing sideways. The intercooler is 1/2" from the firewall, and since this picture, had tabs welded on to clamp it to the strut brace.
Uses a Lightning Intercooler pump.
Old Aug 7, 2008 | 10:56 AM
Damn now thats some use of space! Im in the planning stages of an S480 build and I know Im doing A2W but since its a drag car I dont know if I want to just do and intercooler/ice tank all in one... Im not against going an Ice tank inthe back with a pump and a heat exchanger but I was thinking the larger Ice Tank/intercooler being all in one without any external resivours and pumps would be a little easier with the same benifits...
Old Aug 7, 2008 | 01:19 PM
slomarao's Avatar
God, i could imagine working in that engine bay. Nice though, no way i could ever build something like that.
Old Aug 7, 2008 | 09:51 PM
The way its mounted and built, the heatshield and intercooler come off with only two seconds of work, and the hoses are long enough that the entire intercooler slides out a ways without disconnecting anything. Also, as it is higher than the reserve tank, after the car has been sitting a few minutes, the intercooler drains most of the way of fluid.
But man plug changes are a nightmare, and during the first tuning session it was a royal pain. For that reason (and the minor amount of heat soak due to being above the engine) and a rather visually unappealing welding job, its getting replaced with something else.
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
Jake Bialke
Sep 24, 2015 11:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
