Who really know about wastegates?
Old Dec 18, 2005 | 06:51 PM
NZ12'S's Avatar
Talking Who really know about wastegates?
Took out the green (weak) tial sport spring and installed 1 bar blue spring. However, no difference in boost. Had a little over ten pounds with green spring and same with blue?? Checked all the hoses to wastegate and turbo piping. No found leaks. What's the deal. Any help would be appreciated.
Old Dec 18, 2005 | 07:02 PM
SMOKNZ's Avatar
Re: Who really know about wastegates?
What kind of turbo kit?
Old Dec 18, 2005 | 07:17 PM
NZ12'S's Avatar
It's a butt turbo (non sts). garrett turbo tial sportwastegate. It seems to be getting boost creep for some reason.
Old Dec 18, 2005 | 07:30 PM
SMOKNZ's Avatar
First you said you weren't getting the boost numbers, now it's creeping If it's creeping you need to either turn the boost up or get a bigger wastegate. The Tial gate has two ports, you can use a press regulator hooked up from the pressure port to the port on the top of the gate to allow you to run more boost.
Old Dec 18, 2005 | 08:00 PM
NZ12'S's Avatar
I thought creep was when the wastegate was opening below max boost levels and bleeding off boost prematurely? NO?
Old Dec 20, 2005 | 10:41 AM
mn_vette's Avatar
Boost creep is when boost levels creep past the waste gate setting, very bad for the engine. This happens because the wastegate is opened all the way and there is still too much exhaust that spins the turbo faster. The fix is to get a bigger wastegate that will flow more exhaust around the turbo.
What you are seeing is not hitting your boost numbers. You may be creating too much back pressure and blowing your wastegate open prematurly. That's wny SMOKNZ suggested adding a hose to the top of the wastegate. It will help hold it closed.
Old Dec 20, 2005 | 01:18 PM
NZ12'S's Avatar
MN Thanks for the info. ok i have the hose coming form the boost side of the turbo......tee ing- one to the bottom of the gate and one through the manual boost controller and into the top of the gate. Controller wide open.(screwed all the way out) Still it only makes about 11 pounds of boost. Is it possible that the t4 can only produce 11 #'s. As for back pressure, I have pacesetter lt's and 3" all the way back to the turbo...no cats! any good ideas??
Old Dec 20, 2005 | 01:37 PM
96TurboTA's Avatar
Which garret turbo are you running?
Old Dec 20, 2005 | 05:05 PM
NZ12'S's Avatar
That's a good question I think it's hemorphadite! Someone built it and stuck it in the car for me. I can only tell you the wheel sizes and a/r's. Maybe you can tell me. inducer wheel is 64mm ar 1.05 or close to that over 1. something The turbine wheel is small only aobut 54 mm with and ar of .61 ..got any ideas?
Old Dec 21, 2005 | 08:43 AM
SMOKNZ's Avatar
That seems like an awful big A/R for the turbine for a rear mount. It's quite possible that thats all it can make. You may need to get a smaller turbine housing to spin the compressor faster. From what I understood from the STS rear mount kits they run smaller A/R on the turbine because they claim that the hot exhaust has cooled down some by the time it reaches the back of the car. Something to consider.
Old Dec 21, 2005 | 02:23 PM
NZ12'S's Avatar
I have a turbo guy who has access to all the turbo parts. We'll try and put a smaller hot section wheel and smaller opens. Hopefully that will accelerate the gases and spin the wheel even faster. I'll let ya know Thanks
Jay
Old Dec 21, 2005 | 10:29 PM
sleepybu's Avatar
http://www.tialsport.com/documents/w3_tial_38_sp.pdf
sleeperZ96BT
Sep 10, 2015 08:01 AM
96SilverRam
Aug 9, 2015 04:15 PM
Wild1
Jan 19, 2004 08:17 PM
SMOKNZ
Jan 3, 2004 09:03 PM
SMOKNZ
Jun 19, 2003 09:49 PM
