Where do I mount the Vortech MAP sensor and where does it get vacumn???
Old Feb 17, 2003 | 02:01 AM
96 WS6's Avatar
Just like the subject says. Thanks.
Old Feb 17, 2003 | 11:09 AM
1st and goal's Avatar
Never heard of a Vortech MAP sensor but the stock MAP sensor is attached to the front pass side of the intake (on top just behind the throttle body) with two screws and it gets vaccuum from the intake as there is a port it plugs into under the MAP sensor.
Marc
Old Feb 17, 2003 | 12:32 PM
96 WS6's Avatar
With Vortech there are 2 MAP sensors, one connected to the BTM **** and one connected to the PCM. It runs off of a manifold vacumn, I just don't know where to tap it or what size tee I need.
Old Feb 17, 2003 | 02:40 PM
94SLUG's Avatar
MAP + BTM . I have never heard of 2 MAPS?
Old Feb 17, 2003 | 03:06 PM
96 WS6's Avatar
Okay I didn't ask whether I was right or wrong. I asked where you have to put the other map sensor. There is the stock MAP that goes to the PCM and there is Vortech supplied MAP that goes to the timing **** in the car.
Old Feb 17, 2003 | 04:44 PM
If you're connecting to a boost timing master that will pull timing in relation to boost then just get some vaccuum hose and "T" into a vaccuum port on the side of the intake (plenty to choose from).
Marc
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
RUENUF
Mar 13, 2016 03:39 PM
99TransAmWS6
Mar 22, 2015 11:00 PM
Fatdog2
Feb 13, 2015 08:19 PM
