What would a cam like this peak out around?
221/221 duration, .542"/.542", 114lsa
Im looking for a cam thats going to peak out around 6,000rpms to run 10psi from eithe a GT42 or a t76..does this sound like a good cam?
It depends somewhat on cubic inches versus turbo size, then camshaft. For starters, that cam will probably peak well before 6000 rpm regardless of cid. My guess is that it will peak around 5600 - 5700 rpm.
The data that I've gathered on the T76GTS is as follows:
363 cid, 224/236-114, +0 adv, 5900 rpm
383 cid, 224/236-114, +0 adv, 5750 rpm
388 cid, 224/236-114, +4 adv, 5700 rpm
377 cid, 230/230-114, +4 adv, 5800 rpm
You see, the rpm at peak looks like it's related more to cid than the cam spec's. The T76GTS runs out of steam sooner with the bigger engines so the hp peaks sooner. I bet that you'd have to go up to something like 230 on 350 cid or 236 on 383 to get a 6000 rpm peak. At that point, you have to ask yourself, are you helping or hurting the overall combination just to get it to peak at 6000 rpm? Perhaps it would be better to cam if for 5600 to match the turbo the best.
I don't think 222/222 would peak that high, even NA. Here's an interesting dyno test for you:
http://www.turbomustangs.com/project...tdavisdyno.php
302 cid, 226/226 cam, T74GTS turbo, peak hp at only 5350 rpm. So, less cubes, more cam, similar turbo, and a low hp peak (not to be confused with low peak hp).
I'm running a 224/236 cam and it works quite well. I tried a 226/226-114 and wound up switching back to the old 224/236 cam. I've been itching to try 230/236-114 or even 112, but I dont think it would give me more than 25 hp which is 1 psi boost for me.
That's my recommendation for you. 230/236-114, +4. It will make peak power around 6000 rpm on 355 cid with a T76GTS.
Don't get me wrong, the 221/221 cam will be a beast, but it will peak around 5200 - 5400 rpm. I just think you'll make more power at any given boost level with 230/236 and it will rev a little higher.
Oh. I just dont want to bring the car past 6k I know id be leaving power on the table but im concerned with making this motor last a little while and I know I can make more HP if I keep the revs down safer.
Stock cam peaks @ 5250rpm...5300rpm when I had full bolt-ons. Just for reference, my 230/236 114LSA N/A setup peaked @ 6000rpm...my new 224/224 cam hopefully will peak around 5600-5800 in a 383ci...I dont know though.
Superchargers are a little trickier than turbo's. The 230 should peak a little higher due to the IVC being 4 deg later, but there's no guarantee you'll get more hp since it has 15 deg more overlap. In every dyno test I've seen, turbo's seem to make more power with more overlap, but superchargers could go either way.
How about this cam Mike..
220/232 duration @.050
.498/.507 lift w/1.5 rocker .525/.535 lift w/1.6 rocker
114+2 LSA (has 2 degrees of advance ground in).
would something like that work with a turbo or be no good? cuz for the price its almsot worth it being 150$ cheaper for another cam that would maybe give me 5hp
would that cam work for my power range of 550-600rwhp?
Mike
FWIW, the thing about overlap and blowers is a tradeoff. IF you have excess blower capacity (think of an alcohol Hemi), overlap is good as it blows the end gasses clean out of the cylinder. Of course, a lot of fresh fuel and air goes with it (hence the flames). With the small centrifugals we use, you can't afford to blow too much of the charge out the exhaust. Experience shows that for typical setups you want very little overlap at 0.050" and at least 10 degrees more exhaust duration to partially compensate. This leads to relatively wide LSA's (113-116 degrees work best with typical durations).
Rich
Rich
Yeah, I was thinking the same thing.You think this cam is capable of 550-600rwhp? Im just looking for something to get me through the year thats very streetable and makes around 550-600rw with the 76mm on 10-12psi
