what size is the oil feed plug on lt1 blocks?
What size is the fitting i need for the oil feed. I know i should use -3an feed line, but what size is the plug that is in the block by the oil filter?
Re: what size is the oil feed plug on lt1 blocks?
Hey, the years are slightly different but i ended up tee-ing off the oil pressure sensor instead of the tight area above the filter. Read through this
http://www.vortechsuperchargers.com/...s/4gh218im.pdf
Anyways it is a 1/4 NPT fitting. Later....
ChrisFrez
Dec 28, 2014 02:25 PM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
Skull Leader
Aug 10, 2002 11:01 AM
