What is needed to get 8-9 psi out of a S-trim
Old Jun 19, 2003 | 02:54 PM
96Z28/93TA's Avatar
Do I just need to buy a crank and blower pulley? If so what size do I need and where can I buy them. thanks.
Old Jun 19, 2003 | 05:58 PM
engineermike's Avatar
The following equation can be used to calculate boost after a pulley change if you know the boost before the change:
Boost after = Boost before * (old sc pulley / new sc pulley * new crank pulley / old crank pulley)^2
Mike
Old Jun 19, 2003 | 06:48 PM
LWM's Avatar
LWM
And if the above is too complicated, just go for the 7" crank pulley, that will do the trick.
LWM
Old Jun 19, 2003 | 09:47 PM
Camaro_SS/R's Avatar
LWM
If you are considering serious power later and have some extra cash, this is probably the best way. The problem with this is it is very expensive. over $200
The cheaper way is if you are running the 3.33" crank pulley now, you can just install in a 3.125" pulley. Used ~$35.
Make sure you are tune for the increase boost or else it will end up costing $5-7K.
cheers
Old Jun 20, 2003 | 02:03 AM
BOOST FED 95Z's Avatar
On my old s-trim I ran a stock crank pulley and a 2.75 blower pulley and saw 10 psi. This was through stock heads and an aftercooler.
Scott
Old Jun 20, 2003 | 10:16 AM
Scott
That's a good point. It really depend on the system and what your existing crank pulley is right now and maybe use that equation on top.
Because when I was with my 350, I saw 10# with the 6" and 3.125" pulley setup going through a AFR 190's and a mild cam.
Then later on my 396 with the 6" and 2.75" I only see 6#.
--Hugh
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Deadbolt24
Jan 19, 2015 01:29 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
