what kind of plugs with SC??
Old Feb 19, 2004 | 02:25 PM
pwrtripta's Avatar
ok im installing my paxton and a few other things soon (trickflow heads, crace cam, long tubes), what kind of plugs do you guys suggest, and how big to gap them...6psi boost
Old Feb 19, 2004 | 03:31 PM
mn_vette's Avatar
NGK TR-6's
Old Feb 19, 2004 | 07:04 PM
95 Silver TA's Avatar
I like using the NGK TR6 gapped at .35
I would also suggest a MSD 6A ignition box if you dont have one already.
Thanks,
Claude
Old Feb 19, 2004 | 11:23 PM
97WS6SCharged's Avatar
TR-6. I usually gap mine at .40 If you don't already have a box, a BTM would be more useful than a 6A.
Old Feb 20, 2004 | 06:50 AM
IDOXLR8's Avatar
My vote is Autolite 104's.
Old Feb 20, 2004 | 09:50 AM
94SLUG's Avatar
I just started using them, I think my car is much smoother, and easier to start now.
104s@.38
Old Feb 20, 2004 | 10:00 AM
IDOXLR8's Avatar
104s@.38
I am running mine at .032. Are you seeing any benefit with running that much gap?
Old Feb 20, 2004 | 01:12 PM
94SLUG's Avatar
Its a little early to tell, I installed them a few days ago and started the car for the first time in about 3months and just drove it around the block. Its been to cold and icy here to drive, I cant let ya know till this weekend I hope. PLS NO MORE SNOW!
I gaped my tr6's at the same gap, after 3000 miles the gapes where at .42-.45 area and the car still ran good.
What if any difference should there be in .32 gap to a .38 besides heat?
Bill
Old Feb 20, 2004 | 03:47 PM
pwrtripta's Avatar
i do have a 6al box with BTM it came with the kit. thanks for the help guys, 104's should do me fine
Old Feb 20, 2004 | 09:46 PM
96 WS6's Avatar
I'm using 104's gapped at between 32-35
It's hard to bend that stupid prong equally every time.
Old Feb 21, 2004 | 12:29 AM
Roadie's Avatar
Re: what kind of plugs with SC??
I'm running TR6s...
As far as the paxton goes, how are you planning on running long tubes? Just asking because I went through that about 6 months ago. No headers (shorties or long tubes) will work with the paxton due to the location of tubing.
I tried just about everything to get the paxton tubing around the headers to no avail. Finally, I created a new #1 slip-fit primary for a set of Jet-Hot long tubes using a 1 3/4" exhaust donut, some straight tubing, and a homemade flange. It should flow the same, but the new #1 is slightly longer than the original. If it wasn't forced induction, I'd be afraid of the added length messing with the pulses for scavenging...
Anyway, here's a pic of how I routed the exhaust around the paxton intake tubing. Good luck with your project.
http://www.lt1.org/other/jpg/slip-fit.jpg
Old Feb 21, 2004 | 12:17 PM
94SLUG's Avatar
Yep 5 freaking inches of snow on the ground Going to pick up 55gallons of 100 low lead av gas today though .
Old Feb 21, 2004 | 07:21 PM
pwrtripta's Avatar
are you serious??? you cant put headers, long or mids or shorties with a paxton??? im goin to post another post on this subject. please help me with any other info, i want to run long tubes but will settle for mac mid lengths if i have to.
Old Feb 22, 2004 | 01:41 AM
Highlander's Avatar
Edelbrock shorties DO work.. I had them installed.. no problems...
are the TR6s iridium?
Old Feb 22, 2004 | 07:03 PM
Roadie's Avatar
Good to hear. What size primaries and how close was the intake tubing to the header? I have 1/4" of clearnace at most with a 1 3/4" primary.
The TR6s are not iridium, although I think NGK sells an iridium version of the TR6.
