What do your timing tables look like?
yeah, especially from 90-100kpa, but I am interested in 70-100kap. Since we cannot account for boost, the timing in the 100kpa is used for all boost levels. I am just looking to see 70kpa-100kpa though to compare my mailorder tune (so i can tweak it on the dyno).
My timing tables and PE tables are almost stock. I pull timing with a MSD BTM. I add methanol based on the 2 bar MAP sensor that the alkycontrol kit comes with. I would recommend reducing the "throttle position for WOT" to 20% so it will go into PE mode a little earlier.
I'm pulling 1 degree of timing per each 1 psi of boost with the MSDBTM Box. Here are my timing numbers for 100KPA.
Main Spark Advance
8.0
8.0
14.0
16.0
18.0
20.0
21.0
22.0
24.0
26.0
27.0
30.0
31.0
31.0
31.0
Extended Spark Advance
31.0
31.0
31.0
31.0
32.0
32.0
32.0
Main Spark Advance
8.0
8.0
14.0
16.0
18.0
20.0
21.0
22.0
24.0
26.0
27.0
30.0
31.0
31.0
31.0
31.0
31.0
31.0
31.0
32.0
32.0
32.0
Main Spark Advance
8.0
8.0
14.0
16.0
18.0
20.0
21.0
22.0
24.0
26.0
27.0
30.0
31.0
31.0
31.0
31.0
31.0
31.0
31.0
32.0
32.0
32.0
Main Spark Advance
8.0
8.0
14.0
16.0
18.0
20.0
21.0
22.0
24.0
26.0
27.0
30.0
31.0
31.0
31.0
31.0
31.0
31.0
31.0
32.0
32.0
32.0
Just to be clear, pulling timing in the 100KPA is a perfectly acceptable way of tuning. You will just loose a small amount of power in the low boost areas.
I slowly dropped mine off from 80-100kpa when I was 1 bar, I don't have a copy of my old tune anymore, but I ramped down to 10 at 100kpa. I still can't believe you guys run 26 degrees(in the tune, so 30 after adding the 4 degrees) on a boosted car and pump gas.
Yeah, mine is at 26 degrees in the 100kpa cell.
