What do you LT1/LS1 guys run for a boost controller
Re: What do you LT1/LS1 guys run for a boost controller
If I used a manual it'd be a Joe P MBC. Joe started supporting the DSM crowd years ago with a cheap and reliable unit. Never had complaints about. Also I met the guy, which helps.
Electronic (using now) - Apexi
Joe's site:
http://www.joepmbc.com/index.html
On boostcontroller.com:
http://www.boostcontroller.com/index.php?category=4
Forced Performance:
http://www.forcedperformance.net/
For the Apexi AVC-R:
http://www.apexi-usa.com/electronics_savcr.asp
I used the Joe P mbc for a long time with my old DSM's. Never had a problem with them. Very simple, very effective. I havent used the apexi AVC-r personally before, but I've seen it used and heard many good reviews.
I'll give you personal feedback in April
Forced Performance:
I'm currently using a simple dual stage electronic unit from STS. My buddy just swtiched to a Greddy unit.
I'm gonna switch mine over on this new motor but I have yet to decide which one I want. I get Greddy stuff at cost so I might go that route.
Joe's site:
Forced Performance:
Forced Performance:
The Blitz controllers meant for specific vehicles usually have plug and play setups for the wiring. Blitz isn't to helpful at their tech line either, I have one of their FAT-DC turbo timers and they told me it wouldn't work on a camaro. Well it's working
You will need to just buy a universal boost controller and figure it out yourself. Obviously if you went with the AVC-R and wanted it to display injector duty cycle RPM, MAP (only for 2-3 bar sensors) and all the other crap it can do your going to have to tap the PCM yourself and figure out what does what. Personally All I'd want is the adjustablity of boost control per rpm. Might make launching on the street easier.
Im using a manual, upgraded unit from STS, its basically a **** and nothing else, turn it the way you like to go. not sure the brand on it, I will search it out. Works pretty good though.
Apexi's tech support has been top notch since the day I first had problems. I'll call them on monday about their advice on a domestic application. Also ask them how it works with gearing (which isnt vehicle specific, each car must be fine tuned)
And once I get it up and running I'll make an FAQ. Not to mention I know DSM guys tweaked it till they could make a stutterbox out of it with a programmable rev limiter. Launching was just floor it and then let the clutch go.
No guess work needed. Almost as easy as an auto
Joe's site:
Forced Performance:
Forced Performance:
Most of these are either a 0-10 psi regulator, or some sort of needle valve to bleed off some of the wastegate signal. Nothing special.
