What can I expect and can I spray too?
Old Jun 22, 2003 | 10:13 AM
slimdawson's Avatar
I am curious about what kind of numbers to hope for. I have seen such a wide range so I don't really know what to expect.
Here are the specs: 96 LT1/M6, Moroso CAI, CSI H20 pump, OBDI, Tunercat, 1 3/4 SLP shorties, full 3" mandrel exhaust and Flowmaster. It dynoed 291hp/319tq. It ran 13.13@107.2mph.
I have since added Crane roller rockers and picked up 1-2 in the 1/8 but haven't run it through the 1/4. No dyno #s.
On the spray, I dynoed 80 extra hp and 140 extra ft/lbs to the wheels. It ran 115mph in the 1/4.
I have an ATI P600b with intercooler and 2 pulleys. Not sure how many lbs the pulleys are. I think one is an 8 lb. What can I expect on the dyno with a little tuning and a sound motor? Should I be concerned spraying it? I thought about a 50 shot if the afr is right.
Thanks. And if you need any more info, let me know.
Mike.
Old Jun 23, 2003 | 07:06 AM
MEAN LT1's Avatar
Re: What can I expect and can I spray too?
Mike.
Should run pretty good man for a while. Are you on stock compression?...I'll assume you are and if so just be prepared for the rebuild. its just one of those things you have to things you have to be prepared for when supercharging a high compression motor.
Old Jun 23, 2003 | 04:13 PM
Tech's Avatar
Nitrous + blower + stock pistons = boom.
Pick one. Nitrous or blower.
Jeff1904
Jun 5, 2016 05:00 PM
drt
Sep 27, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
