what is better Alk injection or aftercooler
Old Jun 14, 2004 | 10:12 AM
flusz28's Avatar
Please give me the pros and cons of a Alk injection system for my s-trim and pros and cons for a aftercooler setup... which is more effective and will make more hp? 94 z28
Thanks Jeff
Old Jun 14, 2004 | 11:06 AM
Geoff Chadwick's Avatar
The discussion has been done with water/air aftercooler, air/air aftercooler, water, alcy etc. Do a search - there's a pile of huge threads on this.
I say personally IMHO adding alcy to a "Street" setup means one more thing that can be accidentally empty. If that runs out and your system needs it to keep from knocking, you'd be in trouble. I say use both.
Old Jun 14, 2004 | 08:05 PM
flusz28's Avatar
alright i will have to do some searches for posts. also if i found a intercooler off a early 90's thunderbird all i would have to do is just buy tubing to route it to the blower. right?
Old Jun 14, 2004 | 11:34 PM
96 WS6's Avatar
Or you can buy a kit with a GM low sensor in the alky tank and an LED in the car to tell you when it's low... my kit (alky control) has that =)
Old Jun 15, 2004 | 12:50 AM
Highlander's Avatar
Use both....
Old Jun 15, 2004 | 08:05 AM
I'm also doing the same thing. But while knowing the tank is low is good - what happens when you're out playing for a few days and havent filled up? Low or not you could still run out.
Old Jun 15, 2004 | 08:58 AM
flusz28's Avatar
hey guys - well i rarely ever drive the car so i wouldn't have to worry about running low on alk. thunk maybe i will go with the alk setup since i can build it myself.
drt
Sep 27, 2015 04:39 PM
Henson071
Sep 18, 2015 04:01 PM
Slayer
Aug 17, 2015 03:55 PM
Henson071
Aug 4, 2015 09:32 AM
RX Speed Works
Jul 24, 2015 02:25 PM
