A way to reduce boost without pulley change?
I have 2 pullies and the biggest one still gives me around 9psi at 59xx rpm. Is there a way to bleed some boost off without changing pullies?
Would it work if I adjusted the bov to not fully close?
Re: A way to reduce boost without pulley change?
Originally Posted by Kredz28
long tubes and a highflowing catback will bleed some of the boost off.
I can see that simply with a Turbo.
Boost is simply resistance to flow. If you increase the engine flow & the charger supplies the same amount of air, it will make less boost. This still increases efficiency & power. I have seen LS1 cars lose 2# boost with headers, exhaust & no cats, while still running substantially better.
a cheaper method would be to replace your bov with a plastic elbow(no valve). im sure youll loose quite a bit of boost this way.
but unlike less restrictive exhaust, you will loose power instead of gain it.
I already have a good exhaust but it wouldn't have made a difference anyway. Unless I change cams, boost will stay the same. The exhaust valve closes at the same time regardless of exhaust.
I am not going to totally throw away the bov so that is out. I would probably lose alot that way.
And 96speed, I would love to, but I want to keep the motor alive for at least a year.
do you have a boost gauge? if you do, you can experiment and see whats working and whats not.
the restriction on the inlet side of the blower sounds like a good idea.
i actually tried what i mentioned to you today. i replaced the BOV with a simple 1" elbow. its cheap so i thought id give it a try.
i dont have a boost gauge so i cant tell you how much boost it scrubbed off. i know its still boosting cause the ignition retard light comes on when i put my foot down so there is boost being sensed by the secondary MAP that came with the crane ignition/retard kit.
and also, the "but-O-meter" says im only loosing maybe 10 to 20ponies. but you know the but-O-meter isnt very accurate. but my point is, the car is still really friggin fast.
i think if your seeing 9psi right now, and you do replace the BOV with a regular elbow, i think you will still be satisfied with your power.
if you try it, let me know how much boost you lose.
