Walbro 340 Install
Old Jan 27, 2003 | 11:21 AM
Gripenfelter's Avatar
Walbro 340 Install
What does it take to install this pump in an LT1?
I heard there was a problem with the jet pump that needed to be modified and the wiring?
Will it fit inside the harness or is there a big size difference?
__________________
Old Jan 27, 2003 | 11:32 AM
IDOXLR8's Avatar
You may want to email Jack at Racetronix. Sorry I can't help.
Old Jan 27, 2003 | 05:09 PM
Racetronix's Avatar
Post Re: Walbro 340 Install
__________________
The F-LT1 does not use a jet pump. The C5 Vette does.
Here is an excerpt from a previous post that will help in your decision making process:
The LT1 F-body cars have a pump that is inside a plastic bucket. This bucket in combination with the fuel pump in it is designed to draw fuel from the bottom of the tank via suction. This keeps the bucket full at all times so that when the tank is low on gas and you are doing some hard cornering or acceleration the pump does not run dry and start aerating the fuel. This happens as the fuel sloshes from side to side in the tank leaving the center low on fuel. This can cause detonation and possible engine damage. The bucket also allows the car to operate with lower fuel levels in the tank due to its scavenging effect. The bucket can also effect motor cranking time as the priming time is reduced under certain conditions. The return line from the fuel pressure regulator is diverted back into the bucket via a filter sock inside so that the unused fuel also helps keep the bucket full at all times. Keeping the pump constantly immersed in gas within the bucket can extend the pump’s life by not allowing it to be exposed to open air. Open air within the tank contains moisture and in time will cause the pump to rust / seize up especially if left to sit for long periods of time without the tank topped-up (i.e. winter storage). The Racetronix pump assembly is modified so that it will seal in the bucket’s rubber check-valve so that its function is retained. The Racetronix pump assembly is fitted with a factory style fuel tube not a rubber hose. This hose is important as when the fuel module is placed back in the tank it must pivot which can cause the rubber hose to kink. This fuel tube is much more resistant to the solvents in today’s gas and it will not crack, split, swell and collapse like a rubber hose. The standard Walbro kit comes with a short length of 50PSIA rated rubber hose. The Racetronix fuel module is equipped with a one-piece soldered wiring harness made from mil spec. Teflon/silver wire. This is the same type of wire used at the factory as Teflon is the most resistant to deterioration when exposed to gas. This harness has a Walbro connector at one end and GM pins at the other which fit directly inside the factory connector. Due to the age of the F-LT1 cars much of the in-tank connectors are black / corroded. The Racetronix harness replaces all these questionable components. The standard Walbro kit comes with a plastic coated in-line wiring adapter. This adapter must plug into the existing questionable factory in-tank wiring thereby adding additional connections and length.
Jack
Racetronix
www.racetronix.com
Old Jan 28, 2003 | 02:18 PM
Thanx for the info guys.
I was misinformed about the jet pump.
So the 340 comes with the harness to replace the stock LT1 harness?
Old Jan 28, 2003 | 02:21 PM
Racetronix's Avatar
Post
http://www.racetronix.com/Racetronix..._Pump_Kit.html
Nov 18, 2023 07:21 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
87Aerocoupe
Mar 20, 2015 01:23 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
