Vortech S-trim Pulleys
Old Jul 13, 2004 | 11:09 AM
96Z28/93TA's Avatar
I have the stock 6# pulleys right now, what size pulley do I need to make about 8-9# of boost? how much power would you guess it would add? thanks
Old Jul 13, 2004 | 11:47 PM
smackkk's Avatar
I have a 2.95" pulley. The stock size is 3.33 I believe. Its new and never used. I'll take $50 for it.
Old Jul 14, 2004 | 10:06 AM
Camaro_SS/R's Avatar
Boost and the hp depend a lot on your flow and over system setup. A really rough estimate is something like 20rwhp per lb of boost, but don't hold me to that number.
For 9-10#, I would think it will probably need something like a 3.125" sc pulley. WIth the increase in boost you will need to make sure you put in more fuel. If it is a stock motor, I will highly suggest making sure the car is dyno tuned and maybe add in an aftercooler or something in that line.
The new 2.95" pulley for $50 is a good price, but may give you a lot more boost than you are looking for.
Old Jul 14, 2004 | 02:07 PM
96Z28/93TA's Avatar
I have a vortech aftercooler, walbro high volume fuel pump. My s-trim only puts out 4 or 5# right now because of 4200 ft elevation. I also have hard intake pipe and headers and exhaust. Does anyone know how much boost the 2.95" pulley makes on the s-trim??
Old Jul 15, 2004 | 10:49 AM
96Z28/93TA's Avatar
ttt
Old Jul 17, 2004 | 09:09 AM
LWM's Avatar
LWM
FWIW I had a set up and altitude very similar to yours, 3.125 x 7" pulley on the S Trim made around 11psi of boost on the stock engine.
Hope that helps
LWM
Old Jul 19, 2004 | 11:30 AM
96Z28/93TA's Avatar
Re: Vortech S-trim Pulleys
LMW...did you see a big gain in power with the 11psi boost compared to stock s-trim boost?
Old Jul 19, 2004 | 06:30 PM
LWM's Avatar
LWM
Huge difference
When you pulley up, the boost comes on sooner and so you notice it more. Lots more torque in the sweet spot of the power band ... 4,000 rpm
Hope this helps
LWM
Old Jul 22, 2004 | 03:30 PM
96Z28/93TA's Avatar
how many miles did your LT1 last before it blew up on 11psi? thanks for the help
Old Jul 22, 2004 | 06:25 PM
LWM's Avatar
LWM
It never did blow. I always ran good gas + Xylene and religiously checked the scanmaster for any hint of detonation.
I finally rebuilt it after 15,000 miles to increase the displacement to 383.
No visible damage to the engine at all.
Hope this helps
LWM
Old Jul 23, 2004 | 02:09 PM
96Z28/93TA's Avatar
thanks for the info .. I think I will try that 11psi setup that you were running. thanks again
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
