Vortech pulley sizes/boost numbers.
hey guys, i havent bought a boost gauge yet and im trying to figure something out.
ive had some weird problems with my 6psi set up that no one else has has with the same boost.
i had problems with my MAF due to boost and also with my egr, which is due to my pcm having problems reading the boosted map.
anyway, EVERYONE has said that i shouldnt have these problems with only 6psi, so im wondering if my pulleys are the right size.
i got my SC kit off ebay and it was all brand new, the SC pulley says 3.33" and i measured the crank pulley and it was around 6.5" so im thinking that its the 6.66".
what should the boost be with these pulleys and what would it be with the 3.33SC and a 6" crank pulley???
thanks
jeremy
thanks
jeremy
Re: Vortech pulley sizes/boost numbers.
I had the 3.33 and 6.66 pulleys on my old 355 and got 8psi boost. It had 7 psi with vortech's dryer hose before I changed it. I'm running the same pulleys on my 385 with 5psi boost
are those the pulleys that are advertised to make 6 psi?
yeah im still running that dryer hose too. i also put my stock maf back on with the screen. im actually trying to reduce the boost a little for my stock motor.
im sure ive asked you more that once but ill ask again....who did your motorwork on your 355? your forged right?
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
