Vortech oil line help
I am installing the feed line for the blower, i have a 95 so i have the fitting installed above the oil filter BUT there is really no room to run the line, headers are in the way( or close ) can't loop it really......
My ? is how are you rinning your oil feed line ?
thanks
thanks
Re: Vortech oil line help
I ran mine to the hole in the top of the block behind the intake. It was easy to just run it along the brake lines and then down underneath the charger. I called Vortech customer support to make sure it was ok to use that location for oil supply and they said it would be fine.
squarehead
Nov 21, 2014 08:02 PM
