various mods vs. forced induction
what's the cheapest a turbo or supercharger will cost installed? I'm running a 14.6@96 right now on a really crappy track. I'm looking at spending about $1400 on gears, tc, and cutout, which I'm told should cut a full second, so I'd be around mid 13's. what could I run if I got forced induction INSTEAD? I'm guessing it would be in the $4000 range, but let me know!
Originally posted by GhostZ
www.ststurbo.com
www.ststurbo.com
I think you can get a non intercooled, non polished P1-SC kit for $2500-3000 but you'll have to install it yourself. My Vortech wasn't hard to install, but I did pay a professional to tap the oil pan and install the fuel pump.
You guys are right, that would suck to loose a turbo cause some punk took 10 minutes to unbolt it from your car. Can you really see the STS kit when the car is on the ground? I would think they wouldn't be visible as long as the car had ground fx.
Re: various mods vs. forced induction
Rich Krause
STS's FAQs on their website pretty much covered the primary questions that came up in the 20+ page thread here. Explanations with numbers are included. The kit is what it is, and it made the power it did with the modifications that the engine had.
You cant deny its origionality and its current uniqueness among our cars.
people takeing the turbo is something that i would never have concidered.......i'm sure theres a way to hide it better and seccure it in a way that it cant be disconnected simply
the amount of rage i would feel if something like that happend................i'm sure i'd bust at least one organ
personally, I'm seriously considering the STS turbo kit as I have no interest in relocating stuff around in my engine bay for FI, but I think I would build a shroud around it so it would be harder to remove and more protected against water damage...I know the FAQ says water cooling shouldn't be an issue, but I also know that 1200* is approaching the critical temperature for some metals, and cooling it at that temperature would make it very hard and brittle, possibly causing it to crack under stress. I think while doing that I would make the shroud cover the nicely accessible bolt holes too...or make it look like a muffler
No you didn't
