valve springs to use with TFS heads and 10psi from turbo?
Old Feb 5, 2007 | 08:34 PM
TransAm396's Avatar
What should I go with? Im using the stock lifers with 30k on them, and the cam will have no more than a .550 lift.
Comp 987s? Or would they be too hard on my lifters? Ill only be making 10psi..12 at most and spinning the car to 6200 max.(shiftlite on at 6k)
Old Feb 6, 2007 | 07:36 AM
RealQuick's Avatar
Not sure if those springs will be beefy enough. I ran those with XE230/236 and power fell off pretty quick after 6000rpm. Notsure if that is just the nature of that cam or if it was the springs.
Old Feb 6, 2007 | 09:18 AM
Fastbird93's Avatar
LE set me up for the big Comp Beehives (921's I think???) on my TFS heads for the 383 with the D-1SC.
Old Feb 6, 2007 | 09:30 AM
TransAm396's Avatar
Ill be spinning it to about 6, 6200 max
Old Feb 6, 2007 | 09:36 AM
Roadie's Avatar
I bought my TFS heads already set up with Crane 99893 springs, Ti retainers and 10* locks to run with a CC305 and a turbo. I have no real life info on how they'll run yet, but I should know soon.
(I'm a bit worried about the seat pressure and 15+ psi boost.)
Old Feb 6, 2007 | 10:04 AM
RealQuick's Avatar
Hurry up already
Old Feb 6, 2007 | 12:15 PM
TransAm396's Avatar
well will the 987s be ok for 10-12psi and stock lifters?
Old Feb 6, 2007 | 07:39 PM
BMAN'S SCZ's Avatar
Do you still have the springs I sold you with thoses heads? They would work perfect. .600" lift, 145# on the seat and 350# open. That is what they were set up for 10-12# of boost.......John
Old Feb 6, 2007 | 09:00 PM
TransAm396's Avatar
figures..lol..what were the part number on all the stuff?
Old Feb 7, 2007 | 05:54 PM
BMAN'S SCZ's Avatar
They were the crane springs 10308-1 with comp seats. If you want, Email Lloyd and see if he remembers what they were installed at. Good Luck......
Old Feb 7, 2007 | 10:11 PM
TransAm396's Avatar
they are ok with stock low mileage lifters?
Old Feb 8, 2007 | 06:47 PM
BMAN'S SCZ's Avatar
Yes, that was what I was going to run......
nikolt1
Feb 27, 2015 09:10 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
