Twins with Y pipe?
Old Feb 25, 2012 | 03:34 PM
leftoverz28's Avatar
Twins with Y pipe?
I'm not on here too often and I wasn't sure if this belonged in the exhaust thread or on here but I figured people on here might be a bit more knowledgeable.
My question is this; would putting a pacesetter off road y pipe and a loadmouth catback behind a twin turbo setup be detrimental in any way? I realize I won't be getting every little bit of horsepower out of the car that i could, but I started this project over two years ago, I just want to finish it, and since starting the build I have realized that when finished the car will probably have more power than I will ever need.
The car is a 93 z28, m6, 383 lt1 with ported trickflows, homemade kit with twin precision 61mm's. Hoping to make somewhere between 600 and 650 horse to the wheels. Any info you guys could help me out with would be awesome...
Thanks,
Mike
Old Feb 26, 2012 | 06:05 AM
RealQuick's Avatar
Re: Twins with Y pipe?
Obviously condensing 2 banks worth of exhaust into a single pipe via a y-pipe is going to restrict you (as you are obviously aware), but it should be fine for the power levels you are looking to achieve. If you were super concerned, you could mount twin cutouts on the y-pipe for max power situations. I say you'll be fine though.
G-BODYT56
Jan 14, 2022 11:14 PM
Quickss96
Jan 29, 2016 05:56 PM
football4life
Oct 4, 2015 07:48 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
