Turbo LT1 Up and Running
Old Mar 11, 2008 | 08:31 PM
sean-k94z's Avatar
A big upgrade over my D1sc Procharger. I used all scrap stainless/aluminum to build this setup. At the heart of it is a master power T70. The megasquirt system is VERY turbo friendly with it's 4 bar map sensor and on-board boost controller. The .96 a/r exhaust housing provides pretty good response with good top end power. I should have it at the dyno shop sometime this month.
Low profile intake tubing
4" intake with turbo mounted in the same area as the D1sc
Megasquirt Based ECU mounted
Comments/Suggestions welcome.
Old Mar 11, 2008 | 08:33 PM
subarubill96's Avatar
looks good, get us a video more specs on your setup would be appreciated.
Old Mar 11, 2008 | 08:35 PM
sean-k94z's Avatar
Thanks, hopefully I will have time to take more pics/vids this weekend .
Old Mar 11, 2008 | 09:29 PM
jay_rich's Avatar
what does it consit of?? like what turbo, what headers, DIY?? any build pics? Stock motor? PSI ??
Looks good tho!
Jay
Old Mar 11, 2008 | 10:04 PM
sean-k94z's Avatar
Looks good tho!
Jay
Thanks, DIY FTW.
I wish I had build pics, but I'll get some close ups.
master power T70,
two passenger side manifolds one turned around,
4340 H rods/crank
JE pistons 8.8:1 CR
reworked stock LT1 heads that flow about what LT4s do
setup for 10 PSI (more boost to come once I get bigger injectors I'm thinking 70# range)
Stock fans/radiator, A/C still blows nice and cold
Old Mar 11, 2008 | 10:22 PM
jay_rich's Avatar
Niiice same plans as me.I may go with a S400 tho...did u stay stock size or 355? Which rods did u use eagle? And did you need to clear the block?
Sorry for all the Q's Im tryin to buy all of my parts :P
Jay
Old Mar 12, 2008 | 08:30 AM
FireChicken1995's Avatar
hey jay get ahold of realquick on here and im sure he can point you in the right direction on doing your own kit. i use to have a site saved in my favorites that he uses sometimes to order parts cheap.
Old Mar 12, 2008 | 08:51 AM
Tricked-Out-Toy's Avatar
Originally Posted by sean-k94z
Thanks, DIY FTW.
master power T70,
4340 H rods/crank
JE pistons 8.8:1 CR
Are those custom JEs? or are you running a 6" rod?
Old Mar 12, 2008 | 10:32 AM
sean-k94z's Avatar
Jay
355
Eagle rods/crank
And yes I had to clear the block a little. I wanted to keep all the stock accessories and came to the conclusion that the s400 was too big. I know alot of boat guys in the area that use eagle stuff on 1400 HP big blocks and the failure rate seems to be the same as "better" brands.
Old Mar 12, 2008 | 10:38 AM
sean-k94z's Avatar
Shop around, I did most of mine one ebay. I did my whole setup for $1300 ish minus the motor and PowerLT1 ECU.
Old Mar 12, 2008 | 10:41 AM
sean-k94z's Avatar
FireChicken1995
How much boost are you running and with what CR and do you show any knock retard?
-sean
Old Mar 12, 2008 | 01:03 PM
reamo04's Avatar
sean, looks nice. Any chance u can get me a bigger pic of your intake routing?
I just did a hotside build for my car (look in thread called "my turbo progress"). What did you do as far as hotside?
Old Mar 12, 2008 | 02:23 PM
sean-k94z's Avatar
I used the stock crossover and just modified it to fit, I'll try to get some pics this weekend. Turbo systems have so much back pressure I didn't see a point in building headers for my setup.
Old Mar 12, 2008 | 02:36 PM
what injectors are you running? how you liking megasquirt?
Old Mar 12, 2008 | 02:40 PM
sean-k94z's Avatar
I'm running 42# right now I'll upgrade to some nice low impedance injectors soon since the MS based system can drive them without any modification. The MS system is awesome, way more bang for the buck than any other system, plus its the only complete PNP setup that I know of for LT1 cars.
