Turbo header diameter question?
Re: Turbo header diameter question?
You want to use the smallest pipe before it becomes a restriction, in most applications 1 1/2" to 1 5/8" primaries are used. You can go too big, if you go with more than you need thats just more surface area on the tubing for heat to be lost.
Originally Posted by BigBird383
What should the diameter be on a twin turbo exhaust manifold? 1 5/8?
1 7/8?
1 7/8?
1 7/8?
1 7/8?
BTW, smaller diameter headers will increase velocity and turbo spool......
I think it's mostly dependent on the turbo specs and the displacement. 1 5/8 is probably good for a 350-396 motor, and 1 3/4 would probably be best suited to a 400+ CID small block engine. I'm using 1 5/8 tubes on my twin 383 setup.
I am using 1 7/8 tubes for my 388/91mm. The ID of the tube just fits over the port on my heads. Anything smaller and the tube would have been covering the port. Equal length is nice, but not really a necessary in a turbo application. I adopted the "just get there" philosophy from Young's Performance.
Just some thoughts.
Jay
Just some thoughts.
Jay
Jul 4, 2005 05:00 PM
