Turbo Coupler
Old Aug 26, 2007 | 06:01 PM
greggy2belly's Avatar
Turbo Coupler
Where do you want to put a turbo coupler when making a homemade kit? I see people put them in different locations. Also from my understanding all the turbo coupler does is act like a shock absorber in a way? Is that right?
Old Aug 26, 2007 | 10:08 PM
RealQuick's Avatar
[QUOTE=greggy2belly;4829298]turbo couplerQUOTE]
Do you mean flex section? Not sure what you mean by turbo coupler.
Old Aug 26, 2007 | 11:13 PM
Yea, that is what I meant, the flex coupler. I plan on starting my own single turbo build this winter and also plan on going with a T88.
Old Aug 27, 2007 | 08:15 AM
RealQuick's Avatar
There is alot of different opinions on this subject. Many people have run couples, and many have not... with no ill affects. If you run a coupler, it has to be somehwere before the turbo (it will depend on how the turbo kit is designed and layed out). Since you are putting in a flex section, you will need to build a mount for the turbo, or else only one manifold (the one without the flex sction) will support all theweight of the turbo.
Jon
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
95mysticta
Aug 20, 2015 07:43 PM
