Turbo buildup progress pics...
Well, here are some progress pics. I am waiting for two more v-band clamp assemblies and the hotside (not including DP) should be close to done. Just need wastegate provisions (waiting for my Tial 44mm gate) and O2 bungs. This is for a 383 LT1. I used 2 slp passenger side shorty headers. Looking to run 12-15psi with 93 plus meth.
383LT1
AFR210’s (310cfm/220cfm @ .600)
LT4 intake with Monoblade TB
Cam Motion 223/217 or Comp Cam 230/224
M6 with McCleod street twin
9” rear w/3.55 gears
http://www.ls1tech.com/forums/attach...chmentid=33847
http://www.ls1tech.com/forums/attach...chmentid=33848
http://www.ls1tech.com/forums/attach...chmentid=33849
http://www.ls1tech.com/forums/attach...chmentid=33850
http://www.ls1tech.com/forums/attach...chmentid=33851
http://www.ls1tech.com/forums/attach...id=33852<br />
http://www.ls1tech.com/forums/attach...chmentid=33945
http://www.ls1tech.com/forums/attach...chmentid=33946
http://www.ls1tech.com/forums/attach...chmentid=33947
http://www.ls1tech.com/forums/attach...chmentid=33948
http://www.ls1tech.com/forums/attach...chmentid=33949
http://www.ls1tech.com/forums/attach...chmentid=33950
http://www.ls1tech.com/forums/attach...chmentid=33951
http://www.ls1tech.com/forums/attach...chmentid=33952
http://www.ls1tech.com/forums/attach...chmentid=33953
http://www.ls1tech.com/forums/attach...chmentid=33983
http://www.ls1tech.com/forums/attach...chmentid=33984
383LT1
Re: Turbo buildup progress pics...
Originally Posted by 97WS6SCharged
Looks pretty good so far. How are you planning to run the down pipe?
That cross-over pipe is going to hang pretty low where you've got it. If it's not too late, you should think about re-routing it to run between the oil pan and the k-member. Other than that, it looks great.
By the way, here is a pic from a turbotech street kit on an LS1:
http://www.cofba.org/users/smokinhaw...reet/xover.jpg
I have not heard bad things about ground clearance on the kit, but this thing looks lower than mine!! Your right though, in between the pan & k-member will tuck up the best.
Any LT1 owners out there...can someone measure with a tape the distance from the ground to the bottom of the bellhousing?
Nice use of SLP shorties..
http://www.fastblackcar.com/camaro/t...g/DSCF0176.JPG
:-D
You need to cut off those puny flanges (the front one, with the 1/2" long primary on it) is the worst.. and replace them with 1/2" thick flanges. they WILL warp.
:-D
:-D
:-D
hehe! Thanks for the pics...I already had them bookmarked
I hear ya on the flanges. I will leave it for now, but I made a mental note. Too bad you never dynoed your setup. Did it feel strong?
Nice setup, I just recently started snooping aroudn the FI forum and i'm gonna have to pay attention to this build.
Makes me feel inadaquate with my new hairdryer though
P.S. i'm still running those SLP mids, getting a lil rusty but they are holding up.
I posted more pics
Originally Posted by RealQuick
Is that the underhood of a GN? Did you buy a GN or just the turbo?
I've only had it a couple weeks, so I'm just getting into the FI thing.
Its not a GN but the T-Type in my signature actually, its my beater car, and a pretty cool beater at that if I may say so.
