Turbo build! I'm I headed in the right direction?
I new to FI and not sure if this is the right direction to go. I'm hoping to make 500 to 550 HP at the wheels.
Looking at the racer series short block from VRE. Planning on running 15psi of boost. VRE said, they will set the compression ratio to 9-9.5:1 with the 54cc chamber heads I have now, along with a .039head gasket.
VRE Racer Series 383
Compstar 3.750" Crankshaft, Compstar 6.000" H-Beam Rods, Diamond Forged
Pistons, Diamond Pro-Select Piston Rings, Clevite Main Bearings,
Clevite
Rod Bearings, Clevite Cam Bearings, Splayed 4 Bolt Billet Main Caps,
ARP
Main Studs
Stage 2 System with turbo upgrade, Methanol, Installation, and extras
460-500+ RWHP on Lt1
Product Retail Price
Turbo System LS15798 $3,995.00
GT 67 Upgrade (Will support 750 crank HP) $400.00
Methanol System $499.00
42# fuel injectors (think they need to be bigger) $350.00
Electronic Boost Controller (0-15) $150.00
TiAl Blow off valve $300.00
dynoTuning
Clevite
ARP
Main Studs
dynoTuning
Re: Turbo build! I'm I headed in the right direction?
You will easily achieve the hp #'s you want with that setup. There are better turbo options out there, but the STS kit with that turbo will support up to around ~600rwhp.
95chwagon
Jan 13, 2015 09:19 PM
