For those that weld your FI setups together...
Old Jan 3, 2008 | 11:01 PM
reamo04's Avatar
looking at a welder to use to attempt to build some headers just to mess around with (realquick, keep me on the list)
I was looking at this clarke
http://store.summitracing.com/partde...5&autoview=sku
thought it was a pretty good value considering its everything but the gas tank
just wondering if you think that would be okay for welding stuff up?
Old Jan 3, 2008 | 11:11 PM
RealQuick's Avatar
It should work fine. At Lowes, they sell the Licoln Pro Mig 140 for ~$450.
Old Jan 4, 2008 | 12:19 AM
reamo04's Avatar
actually, went there tonight, and here their 550, dont include anything like the clarke kit does
Old Jan 4, 2008 | 12:29 AM
reamo04's Avatar
they did however have the lincoln 125 for like $430
Old Jan 4, 2008 | 12:10 PM
RealQuick's Avatar
Wow, they bend you guys over in Missouri!! I bought mine for $469 ~1.5 years ago. I go to lowes up here in MA about once a week and the price has been rock solid at ~450ish.
I think the clark or the Licoln 125 will be fine. Licoln has a beter name... but you need to see what comes with the kit for the money compared to the Clarke.
Old Jan 4, 2008 | 12:15 PM
reamo04's Avatar
well, over on
weldingdepot.com they have the clarke for 275
at orschelins they have it for like $350
Old Jan 4, 2008 | 12:26 PM
RealQuick's Avatar
well, over on
Order it up! Make sure it has the regulator/lines for gas.
Old Jan 4, 2008 | 12:39 PM
reamo04's Avatar
well, the one for 275 doesnt have the regulator
the regulator is $50.
Or got $366, i can get one with the cart, and regulator. I already have an auto darkening helmet
$366 setup:
http://store.weldingdepot.com/cgi/we...WE6523P-4.html
$275 setup
http://store.weldingdepot.com/cgi/we...ot/WE6523.html
regulator
http://store.weldingdepot.com/cgi/we...ot/WE6540.html
then i could just go down to my local linweld and get an argon tank, correct?
now, has anybody ordered from weldingdepot.com?
Old Jan 4, 2008 | 12:47 PM
RealQuick's Avatar
$366 setup:
$275 setup
regulator
IMO, the cart is worth every penny. You can get the tank at any local welding supply store.
Old Jan 4, 2008 | 12:55 PM
reamo04's Avatar
have u ever heard of weldingdepot.com or known anybody that has used them?
Old Jan 4, 2008 | 01:16 PM
RealQuick's Avatar
I have heard of them. I havent bought anything from them, but I think I read good things on turbomustangs.com in the DIY section
Old Jan 4, 2008 | 03:40 PM
nxfirebird's Avatar
not to step on anybodys work, but headers tubes and stuff like that, that are wire feed together really look bad.
even worse if you use a flex core wire it will really look like a hack job.
i still even have an old flex core welder and it has it uses, but building turbo hot parts it not one of them.
Adam, go to Habor freight and get on of these -
http://www.harborfreight.com/cpi/cta...emnumber=91811
then run get a bottle, and a box of red tip tungson. it will be about the same as the price of that little wire feed.
this little welder will make some very nice welds, and if you can learn to weld thin stuff with this little scratch start tig you'll be killer on a nicer machine.
Old Jan 4, 2008 | 06:10 PM
RealQuick's Avatar
A grinder will make anything look good in the end.
reamo04's Avatar
I didnt even remember the tungsten. Thanks john. Only problem is.....We dont have a 220 outlet, or room in our breaker box to add one
Old Jan 4, 2008 | 06:19 PM
IROCThisZ28ForLife's Avatar
cant you double up on a breaker or two to take the two hots for the 220 line?
