Is there any such thing as a "Bolt on" turbo?
Old Jul 6, 2004 | 04:56 PM
stang_killa94's Avatar
Just wondering if there is a turbo kit out there for LT1s that are truely bolt on. No custom tubing or wiring etc..............?
Old Jul 6, 2004 | 06:28 PM
JZ 97 SS 1500's Avatar
Yes, PTK makes a system that is bolt-on and will take up to a T76-GTS. You can see some pictures of it here...
http://web.camaross.com/forums/showt...hreadid=277039
Jose
Old Jul 6, 2004 | 06:32 PM
Fuzion1's Avatar
Do you have a link to this system? The only PTK systems I can find are for mustangs. Also, I have been looking into the STS system, they claim "bolt-on".
Old Jul 6, 2004 | 06:39 PM
Go to turbogms.com, they have the pictures of the kit as well as what I posted above.
www.turbogms.com
click at the top under multimedia.
Jose
Old Jul 6, 2004 | 06:41 PM
STS does make a kit, though its not really a kit. Its more of a bandaid for the turbo LT1/LS1 market. The turbo mounts at the rear of the car, which is not very efficient, but it will make some power with enough methanol injection.
Jose
Old Jul 6, 2004 | 07:07 PM
LukeZ28's Avatar
The STS kit can be bolted on in under 6 hours and have seen great results. All wiring is included in a single harness. Check the link out below.
JLTurbo STS track vid
Working on some tuning.
Old Jul 8, 2004 | 08:06 PM
Terran2k's Avatar
about the PTK kit, what has to be removed/moved out of the engine bay? can the traction control, a/c and such stay in? battery has to be moved to the trunk? since i think i see the water tank where the battery would be.
Old Jul 8, 2004 | 08:12 PM
Their are several options, the kit can be had with the large tank that requires the battery to be moved. The kit can also be had with the smaller tank that mounts in the back, then the battery can be kept. The car keeps A/C, PS...all the good stuff. The only thing that has to be removed is the air-pump which is not really needed anyhow. Also we are working on doing a Air to Air setup as well. The donor car was pushed back though so it has pushed out time line back a little. But I hope to have some new pics of the A2A setup in a few weeks.
Jose
Old Jul 9, 2004 | 12:31 PM
Dave '97 Z28 M6's Avatar
HP is developping a single turbo system for the F-body. I've got no idea how long it will be before it's out, but their stuff looks good.
Check it out here
Yeah, and I've heard many good things about the PTK systems.
Old Jul 10, 2004 | 04:04 AM
5.0THIS's Avatar
Check it out here
seems like more than a few places have said they were going to make an LT1 turbo system, and then never followed through These guys' other stuff looks nice, hope they follow through and make it.. moe competitions means better products and prices for us LT1 owners!
LeftoverChinese
Jan 14, 2024 03:03 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
blac94Z
Jan 22, 2015 11:19 PM
Hal Fisher
Sep 14, 2002 09:36 PM
