Teaser vid of my turbo setup...
Old Dec 10, 2007 | 01:55 PM
  #61
c0rey's Avatar
Any problems with the engine bay heating up?
Old Dec 10, 2007 | 03:27 PM
  #62
WIDOMKR383's Avatar
Originally Posted by reamo04
so justin, when are you getting yet another tranny since the new th400 is slipping?
powerglide perhaps hehe
A properly built TH400 would be more then enough to handle your power. You might want to check out NCRC converters. Marty just debuted his all aluminum converter at the PRI show, that would be choice for turbo setups. I believe it weights a total of 5lbs while your at it Neil could build you a 400 that would last.
http://www.racingconverters.com/
Old Dec 10, 2007 | 06:19 PM
  #63
1982z28with18s's Avatar
Transmission parts are sitting in the garage, just waiting to tear it all apart. Not sure if I want to do a cam or not though.
I have no underhood temp problems.
Old Dec 10, 2007 | 11:07 PM
  #64
reamo04's Avatar
See, i've often wondered if, in the case of a turbo setup, having a cowl hood would help or not, or maybe like a ram-air hood to keep the air blowing on it
Old Dec 11, 2007 | 06:32 AM
  #65
WIDOMKR383's Avatar
If your building your own 400 check line pressure as that is what destroy's the case lugs down on the intermediate pressure plate snap ring. Or you could put in the case saver bolt through the case and keep the high pressure.
Old Dec 11, 2007 | 06:56 AM
  #66
97s10ondubs's Avatar
hmm, good thinking, wonder if my hood flows enough air to help.
Old Dec 11, 2007 | 08:26 AM
  #67
RealQuick's Avatar
Heat rises... so it will rise up to the underneath of the hood. I would think a cowl hood will help vent that heat.
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
