Superchargers, Best bang for the buck?
I have an 01 SS and I am interested in adding forced induction. I dont care to get max power or push the thresh hold and have to worry about drive line failure. I reallize none of them are a snap click instalation but I would like to hear oppinions on whitch one is best for ease of instalation. Also I am open to suggestions on Turbos, I hear the LS1 favors a Turbo? I have a basic/entry level knowledge with forced induction so this will be a learning experience for me. I appreciate Any suggestions/comments that you might have.
Thanks for your time.
The ATI ProCharger installation on a LS1 is much easier than on a LT1. The directions are more complete amd the whole kit is much easier to install. This holds true for the Corvettes as well. On LS1's the ATI ProCharger is a true bolt on, that is very reliable and will last for years.
Originally posted by IDOXLR8
My buddy is selling his Powerdyne kit for an Ls1. Here is what is included:
headers
injectors
fans
powerdyne kit.
$2200.
I will get more info if you are interested.
headers
injectors
fans
powerdyne kit.
$2200.
The Vortech and ATI kits are both very popular but the ATI will be easier to install. Vortech has two boost options available - 6# (100-110hp gain) with no Aftercooler and 9# that comes with an Aftercooler (140-150hp gain). These two kits come with everything you need for the install (injectors, fuel pump and programming)
ATI has a 4# kit that comes with everything you need (uses an FMU). This will give you about 80-90hp. Most people usually go with their 5/7# kit. Gains from this are 100-110hp for the 5# and 130-140hp for the 7#. And then there is the D-1SC kit that makes 8# of boost and will show you a 140-150hp gain. These kits require injectors, a fuel pump and custom programming. The D-1SC works well on modified cars or if you are at a high altitude.
Hope this helps,
Tom
Hope this helps,
Tom
