Supercharged 383 Stroker
Old Jul 3, 2005 | 02:57 PM
Destructo's Avatar
So i'm looking into a 383 stroker with a supercharger and some happy gas injection. Any suggestions on what i should be looking to put into my LT1 to make this happen. I'm shooting for about 500rwhp without the nitrous. Obviously forged internals and an ignition upgrade, but what else should i be looking into for my transformation this winter. Thanks in advance
Old Jul 3, 2005 | 03:00 PM
ddnspider's Avatar
Re: Supercharged 383 Stroker
either a stall and shift kit or a clutch depending on your tranny.you'll need larger injectors,gauges,plus all the other basic mods you'd do if it were a 383 along,ie exhaust,intake,heads cam etc
Old Jul 3, 2005 | 08:04 PM
Destructo's Avatar
I've got the exhaust system planned out...going with Hooker Long Tube Headers, with an electronic cut out, Hooker off road Y pipe and i have SLP Loudmouth exhaust, i know it's going to be loud
What kind of heads should i use, i'm thinking going with a set from AFR. Any suggestions?
Old Jul 3, 2005 | 10:29 PM
ddnspider's Avatar
if you can afford it go AFR or ALLPRO's if not there are plenty of sponsors that can port heads.
Old Jul 4, 2005 | 12:20 AM
engineermike's Avatar
For those power goals, I'd go with ported stockers. There's a very long wait on AFR's and people have made 1000 rwhp on boost, no nitrous with ported stockers.
Old Jul 4, 2005 | 09:37 AM
ddnspider's Avatar
yes they have,but if he can afford to go AFR then its not a bad idea,then down the road hes ready for more power with no problems.I see that you have AFR's as well.
Old Jul 4, 2005 | 09:56 AM
The AFR's have the advantage of a thicker deck, but if the 1000 rwhp guy didn't have head gasket problems at 22 psi, then I don't see where that's a problem.
Also, the AFR's have more porting potential (maybe 310 cfm) due to thicker walls, but again, the stockers have been ported to 290 cfm successfully.
Old Jul 4, 2005 | 10:29 AM
ddnspider's Avatar
and to maximize the potential for a 383 he's going to want heads that would flow as much as possible for the money.ive seen AFR heads ported and flowed lot more that 310.And in case no ones noticed theres only a handful of people that CAN make 1000rwhp with stock heads and no gasket problems,the rest have problems anywhere from 10-15psi with lifting the heads,that why the thicker deck is beneficial,and ill say it again,IF he can afford it.Why be cheap if you plan on more power later?thats just my $.02,take it as you will.
Old Jul 4, 2005 | 01:33 PM
Destructo's Avatar
Where would i look to get my stock heads ported? to this kind of level and what kind of price am i looking at?
My goal is to have 500rwhp, once i reach that goal where i go from there is up in the air. But my first step is the 500rwhp, i'd still like to be able to "cruise" this car a little bit, and have fun around town as well as at the track. Should i go with copper head gaskets with this kind of set up? Thanks for all your help guys
Old Jul 4, 2005 | 02:02 PM
ddnspider's Avatar
500rwhp wont be hard to reach with a blown 383.for a decent port job of your stock heads look to spend about a grand.at that power level you dont need copper gaskets,GM MLS will work fine,some even use just a stock 6.0 ltr gasket for example.just start calling or emailing sponsors and see what they'll do for you.
Old Jul 5, 2005 | 02:07 AM
MEAN LT1's Avatar
Hell if all your wanting is 500rw, you can acheive that with stock displacement, p600b or s-trim, your basic boltons+cam and and with about 10-13psi.You should be just about there. Oh yea, its also been done with stock heads too.
Old Jul 5, 2005 | 07:20 AM
Birdie2000's Avatar
ddnspider, he's talking an LT1, not an LS1. Either way, ported stockers will be fine, and really, 500rwhp shouldn't be a problem in the least with a 383. You could probably even get that without porting the heads and just getting a good valve job, especially if intercooled.
Old Jul 5, 2005 | 08:19 AM
ddnspider's Avatar
no **** sherlock,thats why i said what i said.it still holds.as a matter of fact you restated what i said.thanks
Old Jul 5, 2005 | 08:22 AM
Birdie2000's Avatar
I do agree on the stock heads, however last I checked there is no GM MLS gaskets, 6.0 heads/gaskets, or ALL PRO heads for LT1's, only LS1's. I was just making sure there was no confusion.
Old Jul 5, 2005 | 11:05 AM
ddnspider's Avatar
no didnt mean to confuse him thats why i said "for example" if he can get AFR's go for it,if not other companies can get good flowing heads for about 1000-1500.thats all
