Sts Turbo
Old Apr 27, 2005 | 10:06 PM
1993z28camaro's Avatar
Sts Turbo
Has anyone purchased an STS remote mounted turbo for their lt1? If so how do you like it and was it worth the $3800?
Any dyno or track numbers would be great thanks.
Old Apr 27, 2005 | 10:40 PM
ReducedFat's Avatar
Re: Sts Turbo
Personally, I'd spend the extra green for a PTK kit. Wouldn't want to lose your turbo to a speedbump.
Old Apr 28, 2005 | 12:06 AM
thebrainhart's Avatar
Re: Sts Turbo
I'm loving mine, definately worth the money. And if there was a speed bump big enough to take the turbo out, its big enough to take the axle too, as the turbo sits behind the axle. Your gonna get a lot of flack about the STS, because its different and goes against all tradition, but it works, it works great, and it is priced great.
I havent been to the track or on a dyno with it yet though. I'm still trying to dial in my 383. But before, on my stock engine, it was absolutely awesome.
Old Apr 28, 2005 | 12:21 AM
TMorgan800's Avatar
Re: Sts Turbo
Hey bud.. welcome to the Camaroz28 forum... I was once in your position.. only a few posts.. eager to ask questions.. We all do!
However, I would reccommend a search on the STS turbo systems..
4th from the left.. or..5th from the right.. of selectable quick links.. above this thread.
I personally think the STS systems are great.. Its so easy to install, you get great performance out of it.. and. it sounds sweet.. why not... if you have the money. go for it.
I, being pretty broke, was thinking of a powerdyne 4.5psi system..
anyway, good luck filtering through the STS haters on the forum....maybe someone else will chime in here and give some good advice..
Welcome!
--Troy
Old Apr 28, 2005 | 01:40 AM
camarokid24's Avatar
Re: Sts Turbo
I thought that system was for non header cars. Seems like there wouldnt be enough room for the intake pipe on the driver side having headers. Plus a cat back would not be needed anymore as well.
Old Apr 28, 2005 | 08:24 AM
Antz97ZNJ's Avatar
Re: Sts Turbo
go over to the FI section, you'll find more info on the sts then you'll probably want
Old Apr 28, 2005 | 08:33 AM
WS Sick's Avatar
Re: Sts Turbo
If you have headers you use the LS1 forward pipe that comes a different rout.
Old Apr 28, 2005 | 08:44 AM
Re: Sts Turbo
Where is the FI section?
thebrainhart
What kind of numbers did you get on your stock engine with it?
Old Apr 28, 2005 | 09:28 PM
LukeZ28's Avatar
Re: Sts Turbo
Here you go, this is the testing we did on an LT1.
STS LT1
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
speedracer1280
Sep 8, 2015 06:12 AM
