STS LT1 Turbo update
#46
Right... I don't think I explained it clearly, but I do believe that is what he said and I agree. There are some good and bad attributes with this system, but there is a lot of room for improvements (thermal insulating the exhaust, cam, programming, etc)... I would like to see how this performs when someone really puts some time into it. It is a bit pricey as it isn't exactly 'turn-key'. It will operate but it isn't optimized.
#47
I'd have to imagine that thermal coating the entire exhaust up to the turbocharger would help quite a bit, as would a relatively smaller tube.
There's no denying that you lose a significant amount of energy as the gasses cool, meaning you have to rely more on absolute pressure, so keeping in as much heat as possible and giving the exhaust system between the heads and the turbocharger as small a volume as practical would SEEM to be an excellent idea.
#50
The headers wouldn't make any difference versus manifolds other than heat dissipation. Flow/scavenging is negated due to backpressure in the system inherant to the turbo configuration.l
#51
to use aftermarket headers, according to STS, a Y pipe would need to be fabricated, or if the Y pipe you have is in the same location then yes, it would work.
the smaller I.D. theory is also correct, to an extent. when i was going to do this kit, i was going to use the stock sized piping. increasing to 3" MAY cause extra lag since its more area that has to be pressurized. just remember though, smaller piping means more back pressure.
#52
and also SmoknZ i stand corrected, the equation you posted seems alot more correct then the one that was given to me before by a friend. it came up with like 250cfm when i put in 5500RPM and i just plotted that to .5 Bar, so thats why i said 76% efficiency. my appologies.
#53
#55
If your exhaust side has 18 psi of backpressure due to the turbo... the exhaust has a difficult time scavenging against pressure.
#59
Even when not under boost, the turbine housing itself is a restriction which disrupts scavenging. The idea of tubes in a header-style format to the header has more to do with exhaust pulses 'assisting' the turbine wheel where each pulse helps spin the turbine wheel... the tubes are not used for scavenging.
