Sts kit without upgrading the turbo can I reach.....
I was wondering is it possible to get 550-600 rwhp with the sts turbo kit- without upgrading the turbo. The I'm not 100 percent sure but I think some people made that power without upgrading the turbo?? If it's true are you running stock heads, cam??? - Any info would help - Mike
Re: Sts kit without upgrading the turbo can I reach.....
Here you go
http://www.jlturbo.com/lt1_dyno355.htm
that is with the base kit 60-1 @14psi, but with a small turbo cam. We wanted to test the limits of the kit before upgrading. Just ran 12.1@126 with the car the other night.
What type of suspension/tires? You need to get that 60ft down I'm guessing based on the et/mph. Is it bogging or spinning bad on the launch, and do you have any vids you can send me?
On that run spinning the tires, partially from track prep and from street suspension. BMR lowing springs, ZR1s, and other parts for handling don't help the car lauch. There are plans for a track (60') suspension setup for the car, but the car is a daily so i haven't gone that rought with the car yet. The video will be up soon on the site.
BTW take a look at what happend to the Opti trashed as i went through the traps on that run.
CARiD
Jan 14, 2015 04:00 AM
CARiD
Dec 26, 2014 04:20 AM
