Stock Injectors - LS1?
Old Aug 28, 2003 | 03:21 PM
racr4jc's Avatar
How much HP can the stock LS1 Injectors handle when adding boost? Anyone boosting on stock injectors? At what point should one consider bigger injectors? 400rwhp? 500rwhp???
Thanks,
Kenny
Old Aug 28, 2003 | 08:48 PM
bowtiepwr's Avatar
>sorry don't mean to bump in on your post , but with the LS1 stock injector question ... are they interchangable with others like the LT1 injectors ?
Old Aug 29, 2003 | 12:13 AM
racr4jc's Avatar
I think fuel injectors are pretty much all the same, as far as compatibility, right? Back to my question, at what point is it advisable to swap out the fuel injectors? Better question, on a stock LS1 running say 5-6lbs boost on an intercooled twin turbo setup, what size injector should I be looking into?
Old Aug 29, 2003 | 11:32 AM
Scott 98Z M6's Avatar
I would say that your best bet would be a 42lb/hr fuel injector. You are better off going a little bigger because everyone always turns the boost up a little more then they think that they will. It gives you some room to grow...
The mileage that you will get out of the stock injectors depends on the year as well. I believe the 97-98 injectors were 28# injectors and the 99-2001 were 26# injectors, then I believe that they went back to the 28s.
Scott
Old Sep 2, 2003 | 03:27 AM
racr4jc's Avatar
so should ~400rwhp be okay on stock injectors?
Old Sep 2, 2003 | 05:26 PM
FireAm94's Avatar
To go further with the ls1 to lt1 injector question....I don't think they are swappable. Aren't the ls1 injectors rated at a higher fuel pressure so they would actually be alot smaller in effect on an lt1?
Joe
Old Sep 3, 2003 | 06:15 AM
Mikael's Avatar
98, 01-02 Injectors = 28lb
99-00 = 26lb
The 28's are good for 450rwhp, 26s die at 425rwhp.
The LS1s are rated at 4 bar (58psi). A 28lb (at 4bar) injector will flow 24lbs at 3 bar. So put a stock 28lb LS1 injector into a stock LT1, it won't know the difference (94+)
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
spearous
Jan 12, 2015 11:03 AM
