SRP pistons for boost?
Old Sep 22, 2009 | 06:16 PM
reamo04's Avatar
http://www.summitracing.com/parts/SR...4&autoview=sku
looking at those, anybody running them?
I know they have high silicone content but was wondering who is running them with success?
Old Sep 22, 2009 | 06:27 PM
Prorac1's Avatar
The SRP pistons are more ment for naturaly aspirated applications. I would step up to a JE. If your carefull and not running much boost you would be fine. But for an indestructable bottom end id run the JE. I run SRP pistons in my 800 hp NA big block chevy with no problems. Hope this helps, Eric L
Old Sep 22, 2009 | 06:47 PM
boosted-lt1's Avatar
I run them in my budget 350. Ran 7psi with the Vortech for about ~5 years. Run about 10psi with the turbo. I have seen 18psi a couple of times on accident.
I think material makes them more of a budget oriented piston for FI. If you can shell out a couple more bucks, might as well get a 2618. Small price to pay if you want to play.
-Scott.
Old Sep 22, 2009 | 08:24 PM
blown94's Avatar
Ive got the KB 2618's now but the problem is they dont make a shelf piston deeper than 18.6 dish, but the price tag was right. I paid 425 for them. I just got my setup together so they dont have any mileage on them so Ill have to let you know. They do have forced pin oilers but they're a step dish. I hung them on scat 4340 I beams, stock crank. I would imagne they're better than the srp's by material anyways, and about the same price. You might be able to get a custom dish but I would wonder about the price at that point. I hear JE is the **** for this game though, but for 800 bux I thought id try something different since Ill likely not see more than 15 psi on this setup.
Old Sep 22, 2009 | 09:20 PM
MikeGyver's Avatar
I made sure to get JE blower pistons cuz thats not the place to save a couple hundred bucks, for a turbo'd motor anyway.
Old Sep 22, 2009 | 10:18 PM
reamo04's Avatar
see, i blew up my mahle 2618's with nitrous. I have a guy that will trade me those pistons for my nitrous kit. I may have a buyer for the kit though, and if that works, i will buy some nicer pistons
Old Sep 23, 2009 | 09:48 AM
jsetzer's Avatar
I have srps in mine and have made over 600hp 700tq... That being said I did start getting a lot of blow by last week and have not tore it down yet. Guessing ring, ringland, or hole in piston.
$250 used pistons and I beat the snot out of them for 5k miles... Guess we will see.
Old Sep 23, 2009 | 02:47 PM
blown94's Avatar
Yeah, that sounds about like my original stock pistons, they were happy for awhile on 150 shot and 6 psi, then one day massive blowby, ring land melted down. Oops.
Old Sep 23, 2009 | 06:57 PM
Z8'S's Avatar
I ran the SRP's with great success in my blower set up ,several years at 24+lbs . of boost Good gas and Good tune are the key.
Old Sep 23, 2009 | 08:44 PM
4SFEDZ's Avatar
im runnin JE's at 670 thru a th400
Old Sep 24, 2009 | 06:57 AM
engineermike's Avatar
I didn't have very good luck with SRP's. I went through at least 3 sets before switching to Ross. They are noisier, but I haven't broken a single one.
Old Sep 24, 2009 | 10:20 AM
bkrepindy's Avatar
600+ RWHP here and been running the same SRP's now for 6 years.
Old Sep 24, 2009 | 11:37 PM
Procharged94Lt1's Avatar
x2...you can run $2k pistons and melt them if you aren't running the motor right. Any part will break once you try and walk the fine line with it..
Old Sep 25, 2009 | 10:21 AM
slomarao's Avatar
diamond is another option.
Old Sep 27, 2009 | 07:53 PM
Lisa33's Avatar
Havent run any other pistons then SRPs in oure boosted LT1, 20+psi 125 hp N2O for last 2 years widhout problem.
Did have som trouble back in 2004 but i cant blame the pistons for my misstakes..
