Some more progress on the 'Bird...
Originally Posted by INTMD8
Looks nice.
I doubt you will have any problems with the blower belt. I would take a big serpentine over a cog on a stick shift street car any day.
I agree with IDOXLR8 about the clamps though, you'll definitely want t-bolts with 18+lbs of boost.
From: I reached back like a pimp and smacked that LS1....
Re: Some more progress on the 'Bird...
Originally Posted by BADST95
Like I mentioned before, I had a "ring" welded on the end of the tubes so that the couplers shouldn't come off. If they do, I'll have to buy those t-bolt clamps. I know... I know... I spent a lot on the car so far... why stop now?
Even with that bead, we have blown hoses off if t-bolts weren't used. Maybe you will have better luck.
Props on a nice setup. I'm so jealous! We have practically the same rotating assembly, heads, oil pan, damper, etc etc etc... but I have no SC
Again, good job and let us know what that beast puts down to the pavement.
There are other posts about this car on this forum somewhere.
But you can take a peak at the dyno sheet and see for yourself.
Dyno sheet
Got gas money for me? 11 mph will make the trip kind of expensive.
Thanks for the kind words!
Dyno sheet
Dyno sheet
11mph? 700+hp should be good for a few more than that
I suppose if I was on the highway using 6th gear for the entire trip.
. Mph-wise? Should make great time!
Ryan
Originally Posted by 96speed
BAD: I think your typo was supposed to read mpg
Ryan
Ryan
I would make good time however.
