some help
Old Jan 26, 2006 | 09:53 PM
cbrakllr88's Avatar
some help
whts up everybody? I just had a couple of questions refering to a procharger d-1sc kit. I will be ordering the kit in less than a month. I was wondering does it come with an arrangement of pullies or do you just get 1 because I want to run 8lbs? Also what size injectors will be necessary for that boost level? And will I need to upgrade the fuel system a little? Thanks for the help. Later.
Old Jan 27, 2006 | 01:38 PM
JWS6's Avatar
Re: some help
Kit comes with one set of pullies. You'll probably want to start with some 42lb/hr injectors and upgrade to a walbro 255 intank fuel pump. I dont run the FMU with my procharger so you may want to look into that. Dont forget to get a tune!
